Check Engine P0420
Old May 28, 2003 | 12:45 PM
vettatude's Avatar
vettatude
Default Check Engine P0420
Ok, so I didn't like the Borla's that came with the car, so I replaced them with a factory system until I figure out what I want. A couple of days after installing the factory mufflers I trip a Check Engine light with a P0420 cat/o2 problem. I have reset the ecu to try and get it to re-learn the stock flow characteristics, but I keep tripping the light. Questions: Will the computer ever re-learn and stop tripping? Should I just get some o2 sims? Do you really think my cats are failing? This light is starting to **** me off. :banghead:
Thanks for the help
Bill
Old May 28, 2003 | 02:42 PM
vettatude's Avatar
vettatude
Default Re: Check Engine P0420 (vettatude)
Anyone???
Old May 28, 2003 | 02:48 PM
ICULUKN-C5's Avatar
ICULUKN-C5
You could get o2 sims, however you may want to check, with autotap, if your o2 sensors are switching. If you have a bad o2 then decide if you want to replace it or sim it.
To Check Engine P0420
