LIFTER NOISE?
Old May 29, 2003 | 12:06 PM
Bad Bob's Avatar
Bad Bob
Default LIFTER NOISE?
I think this subject was touched on before but I would just like some reassurance, I just had the CARTEK h/c package installed and my car runs great but it seems like the lifters are always making a ticking sound. I heard some other people say this is normal, when I did the h/c change the heads came ready to bolt on with new springs and things. The heads are stage 2 heads and I did not replace the lifters as they only had approx. 20k on them, we did get new pushrods from CARTEK as well. I've heard some guys talk about with these types of heads and a large cam you just have to get used to the noise and it could possible be the springs and not the lifters at all. I'm getting used to the car sounding like a sewing machine but I just want to make sure there is nothing wrong as I have a fair amount of $$$$$ invested in this car now. Thank you advance for any insights. Bob
Old May 29, 2003 | 02:12 PM
SvenOdin's Avatar
SvenOdin
Default Re: LIFTER NOISE? (Bad Bob)
I can relate. After getting my H/C I noticed the sound right away and mentioned it to the vendor whom did the install and he indicated it was normal.
Kinda sounds similar between a slight metalic tapping sound and the sound one hears from a card in bicycle spokes. Sewing machine sound is a good comparison as well!
The sound never goes away, and seem to flucuate with rpm's...
Old May 29, 2003 | 02:21 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
I too have Cartek's stage II heads and they did the install. I was told the sound is normal for h/c car.
I just this past weekend was drag racing at Beech Bend in BG. Some guys were not wearing their helmets so I decided not to wear mine.
On that first pass without my helmet I had to get out of the run as it sounded like my engine was going to blow up, sounds I had never heard before!
I ran the next run with helmet to see if I was hearing things that had been there before but I did not hear due to my ears being covered up.
I did not hear this noise with helmet on.
Chuck
[Modified by chucschramm, 1:23 PM 5/29/2003]
Old May 29, 2003 | 02:45 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: LIFTER NOISE? (chucschramm)
Hell, it's normal for stock LT1s and LS1s, too! :lol:
Old May 29, 2003 | 03:56 PM
see5's Avatar
see5
I envision it as the valves slamming shut driven by the new super heavy valve springs.
To LIFTER NOISE?
