Pressure sensor working or not?
Old May 30, 2003 | 06:07 PM
martinm1021's Avatar
martinm1021
Default Pressure sensor working or not?
Anyone know of a way to tell if a pressure sensor is operating without the wheel being on the car. I'm replacing a damaged rim and would like to know if I can use the same sensor or not, before I have the tire mounted.
Thanks for your help
Martin
Old May 30, 2003 | 06:50 PM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Default Re: Pressure sensor working or not? (martinm1021)
You can train the sensor while it is out of the wheel/tire assy but there is no way to turn it on and read the pressure... chances are that if you retrain it and it honks the horn... it's gonna work fine. grab your magnet and get busy!
