TOP THIS!!
Old May 31, 2003 | 09:55 AM
ndirishr1's Avatar
ndirishr1
Default TOP THIS!!
Has anyone replaced a convertible top on a C5? Is this doable at home? Where can I get some how to info?
Thanks, Greg :confused: :confused: :confused:
Old May 31, 2003 | 01:44 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: TOP THIS!! (ndirishr1)
What does GM charge for a new top ??
:cheers:
Jeff
Old May 31, 2003 | 01:49 PM
CAPN17's Avatar
CAPN17
It is not doable at hoem, hell the experts have a rough time getting it to fit properly in the shop.
Old May 31, 2003 | 02:18 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: TOP THIS!! (CAPN17)
I bet it can be done, after the first time it should be easy. Just be prepared to make a lot of adjustments to the frame.
Old Jun 1, 2003 | 12:45 PM
Kenny94945's Avatar
Kenny94945
Please keep us (well me) informed if you do this at home.
MidAmerica and the like sell tops for $500 that they say are OEM.
I think labor is a good 8 hours of real time.
The service manual is highly detailed for a DIY. Two people would also help. Fist step is to remove the entire top assembly from the Vert and place the asy on a table/ bench for the replacement. Re-adjustments once the new top is installed I beleeive are within the realm of the DIYer.
I do strongly agree that experience with convertible tops can be very desirable. The lack of wrinkles being the biggest issue I suppose. That is why I would like to know what you decide and very much would like to follow your DIY repair if elected.
Lastly, there are two tops with the later year top being more insulated. The headliners differ. I think they changed the top in 2000. Are you going to retrofit?
Personally, I would DIY it.
Just had a warranty replacement so I am good for another 5 years +-.
Old Jun 1, 2003 | 11:31 PM
ndirishr1's Avatar
ndirishr1
If I try this at home I'll let you know how it comes out. I changed the top on my '68 this weekend. I'm not ready for the upholstery shop yet but it came out okay. Couple of goofs but nothing serious.
[Modified by ndirishr1, 10:32 PM 6/1/2003]
To TOP THIS!!
