Engine Check light...
Old May 31, 2003 | 10:48 AM
6_Speed_Man's Avatar
6_Speed_Man
Cruising
Default Engine Check light...
Put a K&N filter on my 98 C5. Small air leak on the engine side of air flow sensor. My fault.. Engine check light came on. I fixed it. NOW How do I turn the engine check light OFF? :withstupid:
Do I have to clear engine codes? How does one go about doing that?
[Modified by 6_Speed_Man, 3:50 PM 5/31/2003]
Old May 31, 2003 | 11:40 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: Engine Check light... (6_Speed_Man)
http://www.stengel.net/diccodes.htm
Old May 31, 2003 | 12:46 PM
6_Speed_Man
Cruising
Problem solved! Thank you so much. Richard is the KING :cheers:
To Engine Check light...
