Predator vs. Hypertech
Old Jun 2, 2003 | 07:43 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Predator vs. Hypertech
Will the predator make any difference for me with the limited performace mods that I have listed in my sig? Or is the hypertech ideal for my application? Thanks
Old Jun 2, 2003 | 08:33 PM
MYY2KVET's Avatar
MYY2KVET
Default Re: Predator vs. Hypertech (ccajun4real)
Well the Predator will match the Hypertech's programming capability (actually more flexiability) plus add diagnostics as well. You can pull and clear codes and do realtime monitoring... Kind of nice actually and in my opinion worth the extra couple of dollars, especially if you are looking at a retail Hypertech.
Old Jun 2, 2003 | 08:43 PM
Killrwheels's Avatar
Killrwheels
Default Re: Predator vs. Hypertech (MYY2KVET)
:iagree: , the scan tool alone is worth the extra $$$
Old Jun 2, 2003 | 09:05 PM
rodknock's Avatar
rodknock
I would just like to add that the Hypertech can install fan changes while still retaing your stock tune,which can't be done with the Predator. The reason being for this is I'm hearing with an after market Mass Air such as SLP's, the tune in both the Preadtor and Hyper Tech conflict with each other. I've been hearing the engine actually leans out and has been causing damage. It seems that you should run a stock tune then modify fans.
To Predator vs. Hypertech
