I am installing my new motor and need some help with the wiring around the starter. here is what I have.
5 wires
thick black wire
thin black wire
thin purple wire
two wires together red and brown
One little wire purple - goes to the small terminal on the starter
The two wires connect on the bottom terminal of the starter\
the thin black wire gets bolted to the block.
My question is where does the large black wire get bolted to? Starter? block?
Phillip
