T1 endlink question
Jun 6, 2003 | 09:57 AM
T1 endlink question
How does the T1 endlink bolt assymbly mount to the lower A-arm/Bar? What i mean is does each bolt head sit up against the A-arm and sway bar (respectively) with the rest of the spacers assymbled in this manner:
Bolt-Head| Bar| Fat-Spacer| Endlink| Thin-Spacer| Nut
Bolt-Head| A-Arm| Fat-Spacer| Endlink| Thin-Spacer| Nut
From what i can see under the car (car is lowered) the endlinks appear to be vertical (ie. perpendicular to both A-Arm & Sway bar).
Also what's the proper TQ (ft-lbs) for the endlink bolts? I used the stock TQ setting of (55 ft-lbs).....if i remember right. :)
Thanks!
[Modified by 97C5ENVY, 8:58 AM 6/6/2003]
Jun 6, 2003 | 11:50 AM
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Re: T1 endlink question (97C5ENVY)
TTT
Jun 6, 2003 | 12:34 PM
Cruise-In III Veteran
Cruise-In IV Veteran
Also interested in this info. I have a set of T1 bars on the way.
Jun 6, 2003 | 01:52 PM
Jun 6, 2003 | 03:13 PM
I would put in the T1 forum.
Jun 6, 2003 | 09:59 PM
Re: T1 endlink question (see5)
Jun 7, 2003 | 08:39 AM
bolt
short spacer
endlink
long spacer
control arm
nut
front sway bar has male end of link attached to it, rear bar has female end attached to it.
Mark
Mark
