Cost for installing 4:11's
Old Jun 6, 2003 | 11:44 PM
Double Aught's Avatar
Double Aught
Default Cost for installing 4:11's
I am kicking around the idea about putting in 4:11's. How much does this usually cost? Just a ballbpark figure would suffice. Thanks.
Old Jun 6, 2003 | 11:57 PM
NYtoCA's Avatar
NYtoCA
Default Re: Cost for installing 4:11's (sd pacecar)
Got mine from Andy for $1200.....Lawton charged $600 for the install which is alittle high but worth it for me to not have to drive to Andy's.
Of course the perfomance gain is incredible but what most people forget to mention is how much easier the car is to drive. Getting out of first gear is simple and required very little gas to do so. This can be huge if your stuck in traffic.
Old Jun 7, 2003 | 12:01 AM
Double Aught
Default Re: Cost for installing 4:11's (NYtoCA)
1200 is just for the ring and pinion? Andy I take it, is A&A Corvette? I have heard that Lawton is quite high, like the Corvette Shop.
ICULUKN-C5's Avatar
ICULUKN-C5
1600-1800 is about normal. If you have 3:42's you may be able to recoup some of your costs. You can get sell your 3:42 for 400-500
Old Jun 7, 2003 | 12:02 AM
Double Aught
Default Re: Cost for installing 4:11's (ICULUKN-C5)
Sounds good to me.
Old Jun 7, 2003 | 02:02 AM
jmzvet's Avatar
jmzvet
The best price that I have found for 3.90 / 4.10 is $1195 plus your core. WEstCoast & A&A sell it for that last time I checked.
Rich, why don't you buy one and we can try installing it? We will do yours first and if it works, we'll do mine :p: .
Old Jun 7, 2003 | 08:02 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Cost for installing 4:11's (jmzvet)
If you send me a carrier I can build them with your choice of ratio for $795. :)
Old Jun 7, 2003 | 08:14 PM
FRC21's Avatar
FRC21
Default Re: Cost for installing 4:11's (CHRIS NJ C5)
Whats the turn around time? Will they whine at all? Can you do 3:90's?
Old Jun 7, 2003 | 08:53 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Default Re: Cost for installing 4:11's (FRC21)
:withstupid:
although I think whining is subjective. Case and point is when I changed rear end fluids, I became hypersensitive (in hindsight) to every sound and rpm pitch. After awhile I forgot about it and now no whine. Go figure. :jester
Old Jun 7, 2003 | 10:07 PM
BLUTHUNDER's Avatar
BLUTHUNDER
I would reccomend the 3.73's or 3.90's over the 4.10's.. I find with the 4.10's your always in the redline.
Not to mention that if your considering hitting the track chances are you'll need to hit 5th gear .
JMHO
:cheers:
Jeff
Old Jun 7, 2003 | 10:35 PM
Double Aught
Default Re: Cost for installing 4:11's (BLUTHUNDER)
JMHO
:cheers:
Jeff
Is your car a daily driver? I only drive mine on weekends. Is there an apreciable difference in acceleration with a 3.90 v 4.10?
[Modified by sd pacecar, 7:35 PM 6/7/2003]
Old Jun 7, 2003 | 11:08 PM
Cruise-In V Veteran
Default Re: Cost for installing 4:11's (Dugmole)
Hey Guys, turnaround time is 1 day. If I get the gears in the morning I can usually get them out by the end of day. We can do any ratio and have not had any problems with noise.. :seeya :seeya
Old Jun 7, 2003 | 11:13 PM
brent eb02's Avatar
brent eb02
good $$$ :eek:
Old Jun 8, 2003 | 12:50 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Jeff
No ..I have an SUV that I drive during the week.
I have a spreadsheet that I can email you , it outlines the various RPM/Speed's based on the gearing you select.
:cheers:
Jeff
Old Jun 8, 2003 | 01:50 PM
blktie8's Avatar
blktie8
Put the 4.10's in and give Chris a call at eastcoast supercharging
You'll never shift 5th at the track.
For rpm info check here :
http://www.smokemup.com/auto_math/mph_range2.php
[Modified by blktie8, 1:52 PM 6/8/2003]
Old Jun 8, 2003 | 04:05 PM
SR71's Avatar
SR71
Default Re: Cost for installing 4:11's (blktie8)
If you have an A4,the 4.10's may be a little deep.they are perfect with a m6 though.it cost me $460 to have the differential swapped out by my local dealership.not the gear installed,the complete differential changed out.
To Cost for installing 4:11's
