Coolant Flushing
Old Jun 10, 2003 | 11:41 AM
skidmarc's Avatar
skidmarc
Default Coolant Flushing
any how to links with coolant flush process????
Mind as well put in 170 degree therm while I am at it...any recommendations???
I bought 2 jugs of dexcool...gonna pick up some distilled water....will be ready to go but need process details...lol
Thanks guys
Old Jun 10, 2003 | 02:21 PM
C5 Curmudgeon's Avatar
C5 Curmudgeon
Default Re: Coolant Flushing (skidmarc)
Actually, check the markets in your area for "purified" water that has been filtered by reverse osmosis. This is about as close to pure water as you'll get this side of a laboratory. Just check the labels, it'll say so if it is. I know Great Bear puts it out, and I'm sure others do also. I buy mine at Shoprite. If you can't find it in stores, check the local pet stores that sell salt water fish and specialize in reef aquariums. They sometimes sell RO water too, but at a higher price.
[Modified by eddiep, 4:34 PM 6/10/2003]
Old Jun 10, 2003 | 10:31 PM
cortex's Avatar
cortex
Default Re: Coolant Flushing (eddiep)
Good timing on this as I am going to flush the radiator this weekend:
As I understand it, you drain the coolant from the radiator (which leaves half of it in because you can't drain the block). Then you fill it back up with water, run until the t-stat opens, cool, drain, re-fill, warm-up, cool, drain, refill and repeat as necessary until the fluid runs clear. At that point you are at 50% capacity (all water) so you add the coolant just up over the low mark on the reserve tank?
Are you supposed to use the distilled water when flushing, draining, re-filling, draining, etc? That's the only way I can think of to end up with the distilled water in the radiator. Am I missing something? Thanks!
[Modified by cortex, 9:33 PM 6/10/2003]
Old Jun 11, 2003 | 06:48 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I just did this last week. The service manual says to open the drain - if the draining fluid looks clean, simply drain and refill.
After 5 years (and 40K miles), mine looked exactly like the new stuff. So I simply followed the directions.
Yes, only about 9 quarts came out - leaving 3 quarts in the block - , but I'm not too worried about it.
Good luck,
To Coolant Flushing
