Clutch adjustment needed?
Old Jun 13, 2003 | 01:33 AM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
Default Clutch adjustment needed?
Im in the process of changing my auto to a manual. Ive got it all back together and the clutch does not seem right. I still have it up on blocks but when the clutch is pressed, the gears do not stop turning (Im getting some grinding.) When put into gear, the axles turn with the clutch depressed. Do I need to adjust the tabs on the pressure plate or did I do something wrong? I installed a Z06 clutch, are these adjustable?
