WTF? Cloudy brake fluid?
Old Jun 16, 2003 | 07:01 PM
larrysb's Avatar
larrysb
Default WTF? Cloudy brake fluid?
02 Vert with 7500 miles. I happened to take the cap off the brake fluid reservior and look inside. I've never seen this before, but the fluid was "cloudy" and appeared having something "floating" in it. Like I said, I have never seen cloudy brake fluid before.
It's not discolored, through the tank it still has that light amber color of new brake fluid.
Old Jun 16, 2003 | 10:27 PM
Bugster57's Avatar
Bugster57
Default Re: WTF? Cloudy brake fluid? (larrysb)
Sounds like water.
A flush, refill and bleed is probably in order.
You may even want to rebuild the calipers, rust is not pretty in brake hardware.
Old Jun 17, 2003 | 10:53 AM
Kenny94945's Avatar
Kenny94945
I was waiting to see the other replys.
Yes, cloudy would indicate water.
In my past I have seen a type of film on the top of the brake fluid.
First place a rag and lift of the film, then turkey baster the rest and go for a brake bleed. Perhaps upgrade to Motul or the like.
Old Jun 17, 2003 | 11:07 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: WTF? Cloudy brake fluid? (Kenny94945)
From what I hear, that is perfectly normal discoloration from the black rubber seal on the lid. You can change your fluid like I did but the color just comes back. :yesnod: :cheers:
**EDIT** MY bad, I thought you were talking about the clutch reservoir, I need to slow down and read what I am reading!!! :rolleyes: :D
[Modified by racer44, 8:47 PM 6/18/2003]
Old Jun 17, 2003 | 01:27 PM
Mitch Alsup's Avatar
Mitch Alsup
Do a flush and bleed, and then wait a month and do a bleed. This gives the residual water in the calipers themselves a chance to contaminate the fluid near the calipers. The second bleed will remove this secondary contamination.
Old Jun 17, 2003 | 02:06 PM
VetteDrmr's Avatar
VetteDrmr
Default Re: WTF? Cloudy brake fluid? (racer44)
No, that's the clutch fluid reservoir that causes that, due to the rubber bladder that is immersed in the fluid.
I agree with the other posts, sounds like water contamination to me. Good suggestion about the flush, fill, bleed, wait a month, then bleed again method.
Good luck, and have a good one,
Mike
Old Jun 18, 2003 | 10:51 AM
User 81424's Avatar
User 81424
Default Re: WTF? Cloudy brake fluid? (Bugster57)
I know the pistons are but aren't the calipers alluminum also?
Old Jun 18, 2003 | 09:17 PM
larrysb's Avatar
larrysb
Definitely not the discoloration as in the clutch fluid. I expect that. The clutch fluid has darkened up, but it is clear.
The brake fluid is indeed cloudy, not discolored. I've never seen anything like it. It almost looks like algae growing in it or something.
I guess it is time for a flush and refill. With only 7500 miles on the car, I guess I could get it done under warranty. It's less hassle to do it myself though I suppose.
Any notion how this might have come about? I've owned the car since new and I've never had occasion to even remove the reservoir lid.
Old Jun 18, 2003 | 10:11 PM
Bugster57's Avatar
Bugster57
Brake fluid sucks water bigtime. Possibly the reservoir cap was not sealed securely?? or possibly contaminated from the factory.
I've seen warnings before against using an opened can of brake fluid, even if the top is on.
Old Jun 18, 2003 | 10:49 PM
Racer's Avatar
St. Jude Donor '11
Default Re: WTF? Cloudy brake fluid? (VetteDrmr)
Your right, I thought he was talking about the clutch reservoir. :rolleyes: :banghead: :banghead: I need to slow down and read what I am reading. :bb :D :D
Old Jun 19, 2003 | 12:05 AM
6 speed Sid's Avatar
6 speed Sid
What's the purpose of the rubber bladder in the clutch fluid holder? Looks like it takes up most of the capacity. If it is for moisture, looks like overkill. Thanks Sid.
Old Jun 19, 2003 | 11:54 PM
VetteDrmr's Avatar
VetteDrmr
Default Re: WTF? Cloudy brake fluid? (6 speed Sid)
Sid,
Because there is so much relative fluid motion in the clutch system as opposed to the brake system the bladder is used to allow the fluid level to "breathe", for lack of a better term.
Hope this helps, and have a good one,
Mike
Old Jun 20, 2003 | 01:34 AM
Racer1x's Avatar
Racer1x
Mine did the same thing, looks like something is floating in the fluid. It came back and I'm on the second flush.
Does anyone know where that presure bleeder is sold?? (To bleed the brakes).
Old Jun 26, 2003 | 09:56 PM
larrysb's Avatar
larrysb
Default Re: WTF? Cloudy brake fluid? (Racer1x)
I flushed mine this last weekend. Sucked it out with a vacuum pump from the reservoir and at each bleeder screw. Couldn't get it all out as the reservoir has a wall in it between compartments.
A few days later, my fluid looks cloudy again.
I have no idea.
The cap on the brake fluid is not real tight, but it seems exactly the same as two other brand new C5's I looked at. So I guess it is correct.
Old Jun 27, 2003 | 01:43 AM
SHOWTIME!'s Avatar
SHOWTIME!
speedbleeders :thumbs:
Old Jun 27, 2003 | 10:11 AM
Kenny94945's Avatar
Kenny94945
Two items,
1 - without a Tech II, the ABS system value doesn't open so some old oil remains in there.
A DIY way to get some of that oil flowing is to do some ABS stops (which open the valve).
2 - Could be that the reservoir has a film on it contaminating the new oil.
So IMHO more bleeding is called for. Put a quart of more through the system.
Old Jun 27, 2003 | 12:42 PM
ryan0's Avatar
ryan0
When i cleaned out my clutch reservoir the fluid was jet black.. like ink.
To WTF? Cloudy brake fluid?
