HOT TIP! Window fix for motor/Reg.
Old Jun 26, 2003 | 01:18 PM
vettemike182's Avatar
vettemike182
Default HOT TIP! Window fix for motor/Reg.
Since I bought my 99 FRC, the passenger window has not worked. I removed the door panel, checked all connectors, checked grounds, checked DIC codes, slammed the door with the button depressed....all to no avail.
Then this week in a tread started by "Marks99FRC" , that has the same problem, a helpful forum member " Seamoore" suggested that the door panel be removed, and the Motor/Regulator unit be tapped (hit) while depressing the window button. Volia!!!!!! She's working now!!!!!
Near as I can tell, the regulating gearing may park at the upper limits, (or just slightly above the upper limits), of travel in such a way that the motor does not have enough torque to un-park them. Tapping on the unit helps the elec. motor do it's thing. To prevent this from reoccuring, I may olny roll the window full up with the door closed. ( Might Help)
Again thanks to Seamoore for his timely tip!!!! And to Marks99FRC for starting the thread!
:party:
Old Jun 26, 2003 | 04:25 PM
allanlaw's Avatar
allanlaw
Default Re: HOT TIP! Window fix for motor/Reg. (vettemike182)
It's (almost) always the passenger side window, since it's not used as often as the driver side window. Tip - once a week, make sure you lower and raise the passenger side window just to keep it exercised :thumbs:
Old Jun 26, 2003 | 06:48 PM
SEAMOORE's Avatar
SEAMOORE
VETTTEMIKE182
Glad it worked for you. Mine has quit several times and this remedy has always worked. I've even divised a quicker way! Do not remove the door panel. Remove the plastic trim around the door release and push away the black goo patch underneath to open up a small hole. Place a screwdriver downward against motor and rap lightly with a hammer while pressing down button. Be careful, the motor connectiing wiring is real close and you don't want to bang on it. Check it out w/ a light first and you will see what i'm talking about. I fixed mine 3days ago in about 7-8 minutes. Good luck.
Old Jun 26, 2003 | 10:52 PM
ILVET's Avatar
ILVET
St. Jude Contributor
Really appreciate the Tip. I'll try it this weekend and see if Im as lucky.
Old Jun 27, 2003 | 11:54 AM
marks99frc's Avatar
marks99frc
Default Re: HOT TIP! Window fix for motor/Reg. (Hildy)
I haven't posted any replies as I have not had the time to take the door apart, but this sounds like it may save me some time. I'll try it this weekend.
Old Jun 27, 2003 | 01:12 PM
tboneinsc's Avatar
tboneinsc
Default Re: HOT TIP! Window fix for motor/Reg. (marks99frc)
Wish I had known about this before I spent like $450 to get mine replaced!
Old Jun 27, 2003 | 01:29 PM
vettemike182
Default Re: HOT TIP! Window fix for motor/Reg. (SEAMOORE)
VETTTEMIKE182
Man you are Da man! You got more hot tips than a B-B-Q cookoff! Mine has worked just fine since I free'd up the motor., But I like your idea of going thru the door latch shroud. Crossing my finger it keeps on working.
I wonder if all the widow lockups have been in the full up position???? That would substantiate my gear over-travel/low motor torque theory.
:cool:
Old Jun 27, 2003 | 01:35 PM
SEAMOORE's Avatar
SEAMOORE
All of my failures have been in the up position also. I've seen lots of comments on this here on the forum and i don't recall one being in the down position. I think you may be on to something w/ your over travel/ low torque theory.
To HOT TIP! Window fix for motor/Reg.
