What's the biggest bore/stroke for a 6.0
Re: What's the biggest bore/stroke for a 6.0 (brrymnvette)
All block can be overbored to 4.03", but some blocks you can overbore to 4.06". A sonic test will let you know how far you can overbore. A crank with 4.125" stroke will require no extra work.
4.06 x = 4.125 = 427 CID :)
Keith
Keith
Re: What's the biggest bore/stroke for a 6.0 (extremecorvette)
Augostine Racing is getting a 436
Keith
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Re: What's the biggest bore/stroke for a 6.0 (kromberg)
Agostino Racing does not get 436ci from a 6.0L steel block. They are using their 4.100" Resleeved Aluminum block with a 4.125" stroke crank to get 436ci.
The most ARE will bore a 6.0L block is 4.030 and when matched with a 4.125" stroke crank gives 418ci I believe.
Re: What's the biggest bore/stroke for a 6.0 (MattG)
[Modified by Chris@SpeedDemon, 11:14 AM 6/18/2003]
Re: What's the biggest bore/stroke for a 6.0 (Chris@SpeedDemon)
They might not be, but we are. :smash: :smash: :smash: We should have results in the next few weeks depending on heads!
I remember a forum member had a custom 4.250" crank built a few years back and never had much luck with it.
What rod length would you use?? I am interested to see the results.
Keith
[Modified by kromberg, 3:07 PM 6/17/2003]
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
All ironblocks block can be overbored to 4.03", but some blocks you can overbore to 4.06". A sonic test will let you know how far you can overbore. A crank with 4.125" stroke will require no extra work.
Keith
Keith
427cid in my honest opinion with 4.060 bore and 4.125 crank is as big as i would want to go with the 6 liter LQ4. That is exactly what MTI built me this past winter! I believe 4.250 would be wayyy to big o a stroke.
[Modified by MTI 427 Roadster, 3:25 PM 6/17/2003]
I was talking to Shirl Dickey about the 4.250 stroke and the clearance issues were too much to overcome in his oppion. A lot of people will punch the iron block to 4.06 but it leaves little to work with after that, not saying it can't be done.
Re: What's the biggest bore/stroke for a 6.0 (MTI 427 Roadster)
427cid in my honest opinion with 4.060 bore and 4.125 crank is as big as i would want to go with the 6 liter LQ4. [Modified by MTI 427 Roadster, 3:25 PM 6/17/2003]
Just curious...
What kind of clearance issue did you guys run into with the 4.25" crank?
Keith
Keith
As for how it will turn out, we will have to wait and see... :yesnod: :yesnod:
There is a good amount of clearancing to do.
Keith
i havre just assembled my 6.0 block bored 30 over withha lunati 4.125 crank, lunati billet 6.125 rods, and diamond pistons. no clearance problens except for piston clearnce on # 8 with the relucor wheel, but diamond has since fixed it, i used the ole dremel tool. the problem was i had a set of early design custon pistons, and they now clearance for all strokes, and theyare sweet looking pieces if you are in the market for pistons. other than some assembly new deals such as "dumbell", few plugs, and the alignment of front and rear covers for pan placement, pretty straight forward. should have it in in about 2 weeks.joe
Matt
I want to use the ARE block with 4.125 bore/stroke for 441ci with dierct port nitrous. Have you heard of any problems with this combo?
Re: What's the biggest bore/stroke for a 6.0 (redbob)
Matt
Any particular reason as to why? What is the detriment to putting a longer stroke in a street car? Piston velocity will not become an issue at any kind of sane RPM.
Just curious...
Just curious...
Regardless, I am interested to see how you make out with this engine as it is always great to grab some more cubes! :yesnod:
