Possessed air conditioning???
Old Jun 17, 2003 | 07:39 PM
JCOB2's Avatar
JCOB2
Default Possessed air conditioning???
As I was driving around town today in high 80's weather, my air conditioning kept coming on for no reason. I would hit the off button and it would stay off for a few minutes, and then randomly come back on a few minutes later. I'm 100% sure I was turning it off. Whats the deal?!? Anyone else ever had this problem? It's a 1997. :skep:
Old Jun 17, 2003 | 10:35 PM
keith5's Avatar
keith5
Active Streak: 90 Days
Default Re: Possessed air conditioning??? (JCOB2)
Yea, I dont know why GM decided that they know better than the driver what the f they want. In order to keep your air from coming on via poltergiest you must turn it off before you turn off the ignition. This keeps it from going to "auto" the next time you start it. If I forget I will turn the ignition to AC and hit off after I've turned the car off. :crazy:
Old Jun 18, 2003 | 11:16 AM
427 C5's Avatar
427 C5
I was having the same problem with my 1999 Blazer LT. The dealer said it was the actual "auto HVAC control unit" in the dash. They replaced the whole unit under the warranty. Haven't had any problems since. Hope this helps.
Old Jun 18, 2003 | 11:28 AM
av8or3's Avatar
av8or3
Default Re: Possessed air conditioning??? (427 C5)
In the Vette,the possibility of bad grounds is always there.I had a '00 FRC
with simular probs that was traced to a bad ground.
Old Jun 18, 2003 | 12:44 PM
wwashing's Avatar
wwashing
Check your mode setting. If the little icon indicates that air is being directed at the windshield, the defroster is on. If the defroster is on the a/c cannot be turned off. Depress the mode button until the icon indicating air to the windshileld is off.
Old Jun 18, 2003 | 03:02 PM
TopCat's Avatar
TopCat
Yep...have learned to live with it on my '97 A4. Regardless of the setting when I turn the car off, sometimes I'll start it up and the car decides to turn the air on; then sometimes it happens when I'm going down the road. Haven't tried to figure out what the problem is and I'd hate to try to chase down a bad ground. If you find out what's doing in on yours, please, please let me know what it was.
To Possessed air conditioning???
