Just curious, how can you recognize knock retard?
Old Jun 18, 2003 | 12:43 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Just curious, how can you recognize knock retard?
I've heard people talk about it, and I understand what it is, but what are the "symptoms"? Does the car just not accelerate like normal, does the DIC display a message, or do you have to have some sort of monitoring device to diagnose it?
Thanks :cheers:
Old Jun 18, 2003 | 01:14 PM
minivette's Avatar
minivette
Default Re: Just curious, how can you recognize knock retard? (Cobra4B)
You really need logging software (EFILive, Autotap, EASE, etc) to monitor it.
Old Jun 18, 2003 | 07:58 PM
geekracer's Avatar
geekracer
Default Re: Just curious, how can you recognize knock retard? (minivette)
:iagree:
Old Jun 21, 2003 | 12:01 PM
Jack Behrle's Avatar
Jack Behrle
You proably will not notice it unless you are getting a lot of it. Run any loggiing software and it will stand out in the file. I was getting a ton of KR when I installed a relocated temp sensor on my 99. The KR was so bad that the car felt like it was surging Which it was since the PCM was pulling the timing back to kill the knock. Autotap or EFI Live will define it for you.
Old Jun 21, 2003 | 12:32 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Default Re: Just curious, how can you recognize knock retard? (Jack Behrle)
:iagree:
Have a tech in the passenger seat with Auto Tap (GM scan tool) plugged in and taker out to the hwy for some WOT testing! Any timing retard will show on the appropriate screen on the Auto tap.
Old Jun 21, 2003 | 04:57 PM
los7883's Avatar
los7883
Default Re: Just curious, how can you recognize knock retard? (sweetcharity)
I had the same problem as you...the car felt like it was pulling strong but the times at the track just didn't sound right. I had another forum member AutoTap my car and sure enough there was tons of KR. I have been troubleshooting it for the past month or so and finally bought EFI Live last week. I was finally able to pinpoint my problem today and now know what was causing it...definatley worth the $$$ in my opinion...I would have never have caught it if I didn't have the scanning software...
Old Jun 21, 2003 | 09:26 PM
jfk c5 ls1's Avatar
jfk c5 ls1
Default Re: Just curious, how can you recognize knock retard? (los7883)
so what did you find, and did you find a way to correct the knock?
Old Jun 21, 2003 | 09:39 PM
los7883's Avatar
los7883
Default Re: Just curious, how can you recognize knock retard? (jfk c5 ls1)
The Granatelli MAF was causing the problems...knock was up to 9* with the GMAFS...when I put the stock MAF back on the knock went away....go figure...
To Just curious, how can you recognize knock retard?
