Blackwing install question
Old Jun 18, 2003 | 07:05 PM
LS7's Avatar
LS7
Default Blackwing install question
Just received Blackwing air cleaner. :thumbs: I have a question though. What goes into the hole next to the built in gauge that tells you when the filter needs cleaning? I have a 2000 Vette. Also, does the filter mount with the gauge on the driver side or passenger side? I also think I am going to install the filter at the same time I change my battery. This way the computer will wake back up and be able to set itself according to the new air flow . Sound like a good idea? :confused:
Old Jun 18, 2003 | 07:08 PM
MY1Fast99C5's Avatar
MY1Fast99C5
Default Re: Blackwing install question (LS7)
Your air pump(egr stuff) goes in the hole.Should be a rubber hose and a groumet. If not then get a little filter from autozone. I know my 99 has it but I disconnected it when I put my headers on.
Old Jun 18, 2003 | 07:12 PM
LS7's Avatar
LS7
Default Re: Blackwing install question (MY1Fast99C5)
Is that the S shaped hose that is already going into the stock air filter on the driver side?
Old Jun 18, 2003 | 07:15 PM
MY1Fast99C5
Thats it. :cheers:
Old Jun 18, 2003 | 07:41 PM
LS7's Avatar
LS7
Thanks for the reply! :hurray:
Old Jun 18, 2003 | 07:43 PM
MY1Fast99C5
Your welcome :grouphug:
Old Jun 18, 2003 | 07:45 PM
cfi_luz's Avatar
cfi_luz
Yeah what he said, make sure you pull the fitting off of you stock airbox and transfer it to the blackwing
Old Jun 18, 2003 | 07:49 PM
LS7's Avatar
LS7
Default Re: Blackwing install question (cfi_luz)
Will do. :thumbs: :seeya
To Blackwing install question
