spark plug gap
Old Jun 19, 2003 | 09:59 AM
Jim D's Avatar
Jim D
Default spark plug gap
I just bought a set of TR55IX plugs, and I checked the gap from the factory . They are all .055, is this gap OK, and do the plugs have to be torqued, my plug wires are on back order, I think all you guys are putting in new plugs and wires. My car is a little hard starting , hope this helps, thanks for your help as usual, Jim.
Old Jun 19, 2003 | 10:15 AM
davidfarmer's Avatar
davidfarmer
Default Re: spark plug gap (Jim D)
Those wires are very durable, but if it makes you feel better, buy new ones.
I run .045" due to high compression. You should gap the plugs to factory specs.
Old Jun 19, 2003 | 11:52 AM
chuckster's Avatar
chuckster
I set my NGK Iridiums to .050.. this way if the gap opens with time I am still in spec up to .060..
Smaller gap may also help eliminate misfires
Old Jun 19, 2003 | 01:04 PM
Highroller's Avatar
Highroller
Jim leave them alone and install them the way they were gapped, especially if your Vette is stock, I've got them in my 383 engine in my SS Camaro, after 23k the gap is still around .058. Don't forget that even with the pucks falling the stock plugs they still fire. Plus you stand a chance snapping the iridium tip. Install and :steering:
Old Jun 19, 2003 | 02:39 PM
IM4A2Z's Avatar
IM4A2Z
I gapped my TR55's at .045 on the advice of a local tuner. said it would help decrease the chance of knock under hard acceleration during the hot summer months here in Dallas.
Old Jun 19, 2003 | 06:03 PM
AFVETTE's Avatar
AFVETTE
I just installed these same plugs on my 99 MN6. They came pre gapped at exactly .55. I installed them as is and the car runs great.
Tom
USAF Retired
To spark plug gap
