Clicking sound when i turn?
Old Jun 19, 2003 | 05:07 PM
Mike TexaSS's Avatar
Mike TexaSS
Default Clicking sound when i turn?
When i turn i can here a clicking sound comming from the Z06 wheels...
Are they on too tight? Anyone herd this noise?
[Modified by Mike TexaSS, 4:07 PM 6/19/2003]
Old Jun 20, 2003 | 12:30 AM
Gary2KC5's Avatar
Gary2KC5
Default Re: Clicking sound when i turn? (Mike TexaSS)
Mike the catback hoops over the half shafts and has a tight clearance.
If your intermiediate pipe springs or your rear hangers are getting weak, it's the exhaust clipping the boot clamps.
I just had my torque tube replaced and when I got it home it was clicking like crazy. I took it back and the tech told me over the phone that the clicking was coming from the exhaust because of the free fit into the headers.
If you get it up in the air to check it out, remember the suspension is not loaded and the system is slightly out of place with the wheels in the air. For example, your sawy bar may be touching you catback when up in the air but not when on the ground.
Old Jun 20, 2003 | 10:18 AM
Mike TexaSS
Default Re: Clicking sound when i turn? (Gary2KC5)
No the sound is clearly comming from the front wheels..
Anyone know the tourque rating for the lugs on the wheels.
Old Jun 20, 2003 | 11:49 AM
gonbad's Avatar
gonbad
100 ft lbs. Should be retorqued in a star pattern to 60-65 ft lbs then again at 100.
You could be having a bearing failure as well.
Old Jun 20, 2003 | 11:53 AM
mapman's Avatar
mapman
No lubricants or penetrating fluids on wheel stud, nuts, or mounting surfaces. Wheel nuts, studs, and mounting surfaces must be clean and dry.
Tighten nuts evenly and alternately in order to avoid excessive runout.
Tighten in criss/cross pattern to 140 Nm or 100 ftlb.
To Clicking sound when i turn?
