Torque for Rocker Bolts??
Jun 19, 2003 | 11:36 PM
I think its 22lbs- can anybody confirm- also do I need to use Lokite on the bolts when I put them back in??
thanks
Rich M
Jun 20, 2003 | 12:04 AM
Cruise-In V Veteran
St. Jude Donor '09
Re: Torque for Rocker Bolts?? (RichM)
22 ft-lbs.Yes to Loctite. :yesnod: :thumbs:
Jun 20, 2003 | 12:08 AM
Yes, 30 N-m or 22 lb. ft.
loctite, No
with the engine in the #1 firing position tighten exhaust rocker arm bolts 1,2,7, & 8. Then tighten intake rocker arm bolts 1,3,4,&5.
rotate crank 360 degrees, tighten exhaust valve rocker arm bolts 3,4,5, & 6, then tighten intake rocker arm bolts 2,6,7, & 8
[Modified by Gary2KC5, 11:14 PM 6/19/2003]
Jun 20, 2003 | 02:56 AM
Re: Torque for Rocker Bolts?? (Gary2KC5)
You dont need locktite, but it can't hurt.
If you have ported heads, a dab of silicon or locktite on the bolts is a
must
Jon
http://www.c5howto.com
Jun 20, 2003 | 09:24 AM
Thanks for the responses
Rich M
