First Oil Change
Old Jun 20, 2003 | 01:18 AM
DezertPhox's Avatar
DezertPhox
Default First Oil Change
Guys, I have a 2003 Z06. I currently have 1,003 miles on it and planning to change the oil this weekend. What brand of oil and filter do you guys recommend? Thanks! :)
Old Jun 20, 2003 | 01:28 AM
corvette184's Avatar
corvette184
Default Re: First Oil Change (DezertPhox)
just what the general ordered .......upf44 filter and 5w30 mobile 1 :party: :party:
Old Jun 20, 2003 | 02:02 AM
mapman's Avatar
mapman
Default Re: First Oil Change (corvette184)
:iagree:
Old Jun 20, 2003 | 03:37 AM
DezertPhox's Avatar
DezertPhox
Default Re: First Oil Change (mapman)
Sorry, guys, I can't find my manual. How many quarts of oil is needed?
Old Jun 20, 2003 | 04:55 AM
markcz's Avatar
markcz
7 - get the 5 qt. bottle and a 6 pack of qts. at wal-mart, save the extra singles for the next 2 changes. With a K&N filter from Advance it comes out to about $35 per DIY change.
Another great $5 investment is a magnetic oil drain plug from your local GM dealer. Part #24100042
:cheers:
Old Jun 20, 2003 | 12:48 PM
jimcork1's Avatar
jimcork1
Default Re: First Oil Change (markcz)
:flag Let the oil drain for 20 or so minutes to fully drain. Also make sure the chassy level. I have been doing mine since new. told the wifey.. I plan to buy / trade for new vet w/427 when available. She said :sleep: :sleep: :sleep: not until I have all new furniture, She just got new kitchen for the price of a vet.. :rant: ..
Still w/ 99 nassau blue 3.42
Old Jun 20, 2003 | 07:19 PM
BIG Dave's Avatar
BIG Dave
Default Re: First Oil Change (jimcork1)
1. Drive the front of the car onto Rhino Ramps, turn off, leave in 1st, set emergency-brake.
2. Pull the filter.
3. Pull the drainplug.
4. Jack up the rear with an hydrualic jack so the rear is slightly higher than the front. Use a 10 pound barbell weight between the jack and the aluminum crossmember.
5. Remove filler cap and let drain. I usually let it sit over night but I'm cooky. :crazy:
6. Fill the new filter with Mobil1. Attach to car.
7. Replace drainplug.
8. Add Mobil1 and replace filler cap.
9. Drop rear of car (gently) and get the jack out of the way.
10. Start car, put in reverse, drive off ramps.
11. Reset Oil Life Monitor.
12. Have a nice day! :thumbs:
Old Jun 20, 2003 | 08:03 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Default Re: First Oil Change (BIG Dave)
BD,
I don't know about the cooky part, but your sure a lot more patient than me. :cheers:
[Modified by Dugmole, 7:04 PM 6/20/2003]
Old Jun 20, 2003 | 08:46 PM
redvett01's Avatar
redvett01
You shouldnt change oil until the oil moniter light comes on. Mobil 1 takes longer to break in an engine due to lower friction. You need to change your mind about changing oil every 2-3000 miles the new oils are much better than the older. ;)
Old Jun 20, 2003 | 08:54 PM
Sir Sel's Avatar
Sir Sel
Default Re: First Oil Change (redvett01)
Better safe than sorry. I first changed mine at 580 miles.
Old Jun 20, 2003 | 10:00 PM
PBEY's Avatar
PBEY
Default Re: First Oil Change (Sir Sel)
Sir Sel do you have the problem thats been discussed on the forum with having to add oil between oil changes?
:confused:
Old Jun 20, 2003 | 11:02 PM
Bugster57's Avatar
Bugster57
Default Re: First Oil Change (PBEY)
6.5 qts. to refill with filter per sm. (Mobile 1 filter - #M107, about $11 @ Autozone) Delco ultraguards too hard to find unless you want to order one. The Mobile 1 filter is a premium filter well.
Old Jun 20, 2003 | 11:54 PM
Sir Sel's Avatar
Sir Sel
:confused:
Yes my burned a little oil when it was stock, about 1 quart 2500 miles and it burns a little more in my 436. Hopefully the ring problem will be fixed permanently on the C6.
Old Jun 21, 2003 | 12:42 AM
DezertPhox's Avatar
DezertPhox
Here is my 2 cents. After changing your filter filled with engine oil, disable the ignition/fuel system and crank the engine (won't start) for not more than 10 seconds and watch your oil pressure gauge until it registers pressure. Restore the ignition/fuel system and start up the car. By doing this, you are priming (prelube) the engine.
Old Jun 21, 2003 | 07:17 AM
Patman's Avatar
Patman
If I had a C5, I'd use 7 quarts of Redline 5w30, along with a K&N HP1007 oil filter. Change it every 5-6k and you'll get an extremely long life out of that LS1/LS6.
[Modified by Patman, 7:17 AM 6/21/2003]
To First Oil Change
