Can EMT's be repaired?
Old Jun 20, 2003 | 08:06 PM
Jumper506's Avatar
Jumper506
Default Can EMT's be repaired?
I picked up a screw in my drivers rear tire and am wondering if I can fix it myself without taking it off the car.Any help is much appreciated. :(
Old Jun 20, 2003 | 08:14 PM
psgarage@ptd.net's Avatar
psgarage@ptd.net
Default Re: Can EMT's be repaired? (Jumper506)
I had a nail in one of my rear tires and I plugged it on the car with no problem. :party:
Old Jun 20, 2003 | 08:46 PM
Jumper506's Avatar
Jumper506
Do I just need tire plug kit from local auto store? :hurray:
Old Jun 20, 2003 | 08:58 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Tread yes, just like any tire. Sidewall, no. Discount Tire will do it for free, you know. :cheers:
Old Jun 20, 2003 | 09:51 PM
RWhite's Avatar
RWhite
Default Re: Can EMT's be repaired? ($$$frumnuttin')
If they are Goodyear EMT's, the will do it free also. However, they have a tread wear % maximum you must be under to do it free. I would just take it to Discount. They like working on Vette's! :D
Old Jun 21, 2003 | 01:15 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Can EMT's be repaired? (RWhite)
I had one repaired ok when in the tread; on another spike in the sidewall, I had to get new tires.
Old Jun 21, 2003 | 06:17 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Can EMT's be repaired? (FunDriver)
Exact same scenario here.
Old Jun 21, 2003 | 04:43 PM
Bob Chapman's Avatar
Bob Chapman
Goodyear told me that you can patch - not plug - a run flat once and they will honor its speed rating if you need future adjustment to the tire. The trick is to find someone who will repair run flats - my Goodyear dealer wouldn't do it.
Old Jun 22, 2003 | 02:45 AM
TimC5's Avatar
TimC5
I had a half inch wide bolt sticking out of mine :eek: Goodyear repaired it and put the ugly wheel weight that was on the outside of the rim, on the inside. :cool: Iv'e been 148 mph since then with no problems. Its holding air fine.
To Can EMT's be repaired?
