Rear view mirror problems and parking brake problems
Old Jun 21, 2003 | 11:14 AM
robl45's Avatar
robl45
Default Rear view mirror problems and parking brake problems
Hi guys, my rear view mirror keeps moving, basically anytime I hit a decent bump, is there a fix for this or do I have to buy a new mirror? Also my parking brake lever pulls all the way up and the parking brake still isn't holding too good, can I adjust that or do I need to work on the brakes themselves?
Rob
Old Jun 21, 2003 | 11:35 AM
fuel524's Avatar
fuel524
Default Re: Rear view mirror problems and parking brake problems (robl45)
You can adjust the Parking Brake, but I believe that you have to take off the rotors to do it. Check out the C5 Tech Tips
Old Jun 21, 2003 | 12:51 PM
Oldvetter's Avatar
Oldvetter
You can tighten the rearview mirror with an hex allen wrench. I have had to tighthen mine several times, when ever it starts vibrating.
Old Jun 21, 2003 | 07:05 PM
jawsski's Avatar
jawsski
Default Re: Rear view mirror problems and parking brake problems (Oldvetter)
I adjusted my parking brake today, among other things. You need to remove the disc brake caliper and then pull the rotor. There is a circular pre-sprung, drum brake with two pads attached. There is a small adjusting wheel that you turn to expand the brake so that the rotor fits snugly back on. Pretty easy except for the caliper bolts are tight. :yesnod:
Old Jun 21, 2003 | 08:17 PM
robl45's Avatar
robl45
Default Re: Rear view mirror problems and parking brake problems (jawsski)
I need to tighten the bolt that holds the mirror to the windshield, but how is that going to fix the mirror getting out of place over bumps, I can't stand readjusting the mirror 2 times a day.
Rob
To Rear view mirror problems and parking brake problems
