Fixing 10-PCM P1416 AIR Bank Code
Old Jun 21, 2003 | 12:35 PM
fuel524's Avatar
fuel524
Default Fixing 10-PCM P1416 AIR Bank Code
I've been getting the AIR Bank 2 code a lot lately, and I know it means that one of the sensors isn't responding right on the manifold, but where is the actual part in relation to the engine or the manifold? What do I need to do to the sensor to fix the problem, do I need to go buy another one? Thanks
Old Jun 21, 2003 | 03:56 PM
SFVetteman's Avatar
SFVetteman
Default Re: Fixing 10-PCM P1416 AIR Bank Code (fuel524)
Usually the problem is a bad check valve in the AIR plumbing above the exhaust manifold. Sometimes the passage in the exhaust maifold where the AIR pipe connects gets plugged. It could also be a kinked hose.
Old Jun 21, 2003 | 08:59 PM
C4C5 Tech's Avatar
C4C5 Tech
Usually with this code there is no air from the AIR pump getting to the passenger bank exhaust manifold. The times i have had this code the Check Valve will not allow air through the valve. I usually replace the Valve and the pipe that it attaches to as sometimes it is almost impossible to remove the valve.
To Fixing 10-PCM P1416 AIR Bank Code
