tire pressure sensor
Old Jun 21, 2003 | 06:52 PM
happyhourvette's Avatar
happyhourvette
Default tire pressure sensor
i have a 2000 c/5 i need a part number for the right front tire pressure sensor. already tried to reprogram with no luck. i went to local dealer part was 120.00 . tried gm direct parts but have to have part number. thanks in advance :banghead:
Old Jun 21, 2003 | 06:58 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: tire pressure sensor (happyhourvette)
The part # for the 97-00 sensor is 10438853 $71.96ea. from gmpartsdirect.com.
All 4 sensors are physicaly the same. The programming procedure is what establishes the location on the car.
:cheers:
Old Jun 22, 2003 | 10:19 AM
Lawmagnet's Avatar
Lawmagnet
Default Re: tire pressure sensor (Y2Kvert4me)
Why didn't the reprogramming not work?? Did you put the magnet on the INSIDE of the rim, under the sensor?? That makes it easier.
Old Jun 22, 2003 | 12:28 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
i wouldn't give up so quick on the sensor.
sometimes it takes several tries before it takes.
do what lawmagnet suggest plus move the magnet around ever so slightly.
Old Jun 22, 2003 | 12:31 PM
Lawmagnet's Avatar
Lawmagnet
Default Re: tire pressure sensor (ROCKnROLL)
I agree....move the magnet around a bit...
To tire pressure sensor
