DRL and IPC/DIC Codes
Did a diagnostic and found the following codes:
40 BCM B0502 HC
40 BCM B0507 HC
40 BCM B2482 HC
28 TCS C1281 H
The three under 40 BCM are the DRL circuits. I know these are in the DIC because I removed the fuse. My question is, will it continue to crop up on the DIC or is there a way to keep them from registering??
The 1281 is something to do with my steering wheel sensor. This has been comming up since day 1 of ownership :eek: Seems like clockwork.....every 100 miles or so I will get the "Service Vehicle Soon" message and this will be the ONLY code in the DIC.
I have had the $tealership look at it as well as Speed DEmon when I had the H/C done. $tealership found nothing (I had already cleared it from memory) and said everything checked out ok. Speed Demon said more than likely it was a bad sensor and I should replace it.
Guess I'll need to purchase the service manuals as I hate to take it to the $tealership....
Anyways, I'm rambling.....back to my inquiry:
DRL codes....will they keep comming back and I have to clear, or is there a way to clear permantly?
:cheers:
When 1281 is set a scan tool may display 2 additional characters after the DTC. These characters are an engineering aid to determine the specific criteria for the DTC to be set.
Service manuals, and access to a scan tool, are in order if you don't want to take it into the dealer.
