Big Problem With Suspension
Old Jun 24, 2003 | 12:51 AM
Reboot's Avatar
Reboot
Default Big Problem With Suspension
Over the past month my Z06 has developed a traking problem that has gotten to point where the car is undrivable. The car wobbles like a rocking boat on any uneven surface, and during deceleration.
I now have a problem with the upper and lower control arm bushings in the rear. These are being replaced with poly bushings this Friday. The thing I can't figure out is now my car sits 1" lower on the passenger side. I'm sure this is the original problem that cause the bushing failures, but I'm stumped as too what could cause this. The 7" lowering bolts on the rear both have exactly the same number of threads showing, yet looking at the leaf spring, one is resting much lower than the other. The fronts are adjusted exactly the same on both sides as well.
Could a broken shock cause this? Any other ideas?
I really need some help here.
Thanks in advance.
Old Jun 24, 2003 | 01:03 AM
'97 C5's Avatar
'97 C5
Default Re: Big Problem With Suspension (Reboot)
Your description of the bolts and ride height sound like a broken spring.
Old Jun 24, 2003 | 03:20 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: Big Problem With Suspension ('97 C5)
:withstupid:
the shocks are not playing in this game. Check the spring for cracks!
Frederik
Old Jun 24, 2003 | 09:47 AM
Reboot's Avatar
Reboot
Thanks Guys! I actually never thought about the spring being broken. I'll drop it and take a look this evening.
Old Jun 24, 2003 | 11:12 AM
gonbad's Avatar
gonbad
:iagree:
Oh Yeah! That really sounds like a broken spring to me. If you have cleaned the engine or underside of the car with a strong grease or oil removing cleanser can cause the spring to delaminate
Old Jun 24, 2003 | 02:36 PM
spdnman's Avatar
spdnman
I'd also bet on the spring. I had a cracked front so I replaced front and rear with Z06 springs and Bilstein shocks and Hotchkis bars. Car is even better than before. It is a stiff ride, but I do not mind at all.
Old Jun 24, 2003 | 03:20 PM
Reboot's Avatar
Reboot
Default Re: Big Problem With Suspension (spdnman)
I just called the local Chevy dealer for pricing on the rear spring. Tha damn thing is $569 dollars. I sure hope it turns out to be something else. Although, I think you guys are probably right, and I'll have to bite the bullet.
Old Jun 24, 2003 | 03:52 PM
JakeL's Avatar
JakeL
I'd check the wheel bearing and your ball joints.
Cheers!
-Jake
Old Jun 25, 2003 | 02:59 AM
C5 Frederik
Mail Gene at Karshop, on the vendor list on the left, for a used one. Great guy with great parts and great service.
Frederik
Old Jun 25, 2003 | 11:24 PM
Reboot's Avatar
Reboot
Default Re: Big Problem With Suspension (C5 Frederik)
Just found the problem. The nut that holds the lower ball joint had loosend up to the point where it was ready to fall off. Tightned it up and everything is good.
Thanks All
Old Jun 26, 2003 | 02:28 AM
C5 Frederik
OMG :bb great that you found it before it got lost!
Frederik
Old Jun 26, 2003 | 09:36 AM
spdnman's Avatar
spdnman
Glad it was a cheaper, easier fix than mine.
Old Jun 26, 2003 | 02:37 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
That beats $569.00 ANY DAY!!!! :cheers:
To Big Problem With Suspension
