C5 Line Lock?
Old Jun 24, 2003 | 05:32 PM
C5EVIL's Avatar
C5EVIL
Default C5 Line Lock?
Is there a line lock available for the C5? If so, where can I buy one from and how much is it?
Thanks in advance for any info! ;)
Old Jun 24, 2003 | 06:07 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: C5 Line Lock? (C5EVIL)
I hear that Cartek has a kit available.........or you can try a self install like me and so many others and end up doing a lot of this------> :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :jester
Old Jun 24, 2003 | 07:07 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Summit Racing has the TCI Roll Stop Kit, Hurst Roll Control, and the Biondo Line lock..... Phone is 800 230-3030 web site is http://www.summitracing.com
Good Luck :cheers:
Bob
Old Jun 24, 2003 | 10:25 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Got mine from Cartek, saved a lot of headaches!
Old Jun 25, 2003 | 09:41 AM
kromberg's Avatar
kromberg
Default Re: C5 Line Lock? (wallstAL)
I bought the TCI unit from summitracing and went to a local speed shop to buy some SS brake hoses and fittings. Cost about a total of $130ish to install everything.
Keith
Old Jun 25, 2003 | 09:52 AM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
St. Jude Donor '03-'04
ARE installed mine :cheers:
Old Jun 25, 2003 | 10:26 PM
WHY2KRAG's Avatar
WHY2KRAG
Default Re: C5 Line Lock? (Buckmaster)
Hurst roll control is the only way to go. A little red button on the shifter press and squeeze . You are out of there. :seeya :steering:
Old Jun 25, 2003 | 10:59 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: C5 Line Lock? (WHY2KRAG)
Installed my hurst in one sunday afternoon, no problems with it. :p:
Eric
Old Jun 26, 2003 | 01:20 AM
BLUBYU2002C5's Avatar
BLUBYU2002C5
Bought mine from summit - TCI Roll Stop - about 70 bucks, I think
I have a 2002 Coupe with Active Handling and let me tell you it was a biscuit to install :mad
My biggest problem was finding the stupid "japanese" fittings and getting the "GM" double Roll Flange on the end of the new line.
I actually ended up taking the stock line and cutting it to tie in with the new line, so i could use the stock fittings, after that not one problem, works great and works real good :cheers:
P.S. i did buy the hardware kit from summit also as recommended, but none of the fittings worked out right, for my car that had active handling, i was also told at the time cartek didnt make the complete set for a car with A/H?? dont know if that is still true.
Old Jul 1, 2003 | 02:57 PM
Wolf1171's Avatar
Wolf1171
From: Winter Jam I and II Veteran, Bahama Jam 2005 Veteran
CI 4, 5, 7, 9 & 10 Veteran
St. Jude Donor '03-'05-'06-'08
Default Re: C5 Line Lock? (kromberg)
Keith
Can you use the braided, stainless steel hoses that are flexible?
Old Jul 1, 2003 | 03:35 PM
kromberg's Avatar
kromberg
Default Re: C5 Line Lock? (Wolf1171)
You need to use the teflon braided hose. The 'normal' braided hose for fuel does not hold enough pressure for brake lines. The teflon braided hose holds 2500 psi.
Keith
To C5 Line Lock?
