[need help!] P0200 and engine running really rough
Old Jun 26, 2003 | 07:44 PM
molon labe's Avatar
molon labe
Default [need help!] P0200 and engine running really rough
topic title says it all.
started the car up, and noticed the engine was running really rough - like it was running on only 4-5 cylinders. limped a couple blocks home. parked it and pulled codes. only current code is P0200. everything looks good under the hood. changed plugs, brake pads, oil, filter two days ago. any ideas, and what does P0200 mean?
thanks!
ken
Old Jun 26, 2003 | 07:50 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: [need help!] P0200 and engine running really rough (tattooed)
I have no idea what a P0200 code is :( Sorry. A P0300 code is a Engine Misfire Detected-B.......which is consistent with a plug or wire issue.
Old Jun 26, 2003 | 07:59 PM
molon labe's Avatar
molon labe
Default Re: [need help!] P0200 and engine running really rough (Buckmaster)
i searched on another forum and found out that P0200 is for "an Injector Circuit malfunction -- which would explain the rough idle and rich smell". commonly caused by chaffed wiring harness. very common on z06's.
time to go out and examine wires. :) hopefully i won't have to tow her in to the dealer for what is going to be a wonderful, clear, warm weekend. :/
will keep ya'll posted.
and thanks for the quick reply Buckmaster. :) :cheers:
Old Jun 26, 2003 | 08:02 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
Good luck. Sorry I couldn't help. I have a "quick list" of codes I keep nearby and it wasn't on there. I'm glad I know what it is now :D Thanks.
Old Jun 26, 2003 | 08:23 PM
molon labe's Avatar
molon labe
i cleared all codes, checked all injector wiring harnesses and wires. found a couple that were suspect. rearranged them so they were clear and had nothing laying on them. everything fine now. :) heheh.
i'll take it in to the dealer next week so they can inspect/replace the harnesses. :)
To [need help!] P0200 and engine running really rough
