Help with Blackwing install!
Old Jun 27, 2003 | 05:54 PM
Z06TheKid's Avatar
Z06TheKid
Default Help with Blackwing install!
I installed the blackwing correctly (I hope) but had trouble getting what I assume is the pvc hose (its a 1 inch thick black rubber hose that attaches to the filter) connected to the blackwing without curving it a bit to get it to fit. What is the fucntion of this hose? Does it matter if its straight or are a few bends ok?
Old Jun 27, 2003 | 05:59 PM
wstory1's Avatar
wstory1
Default Re: Help with Blackwing install! (EBZ06EB)
A few bends are okay as long as the hose isn't crimped anywhere.
Old Jun 27, 2003 | 06:03 PM
Z06TheKid's Avatar
Z06TheKid
Default Re: Help with Blackwing install! (wstory1)
what is the purpose of the hose?
Old Jun 27, 2003 | 10:26 PM
LS7's Avatar
LS7
It's some kind of air pump I think. Ijust installed my Blackwing to. Had to put a little curve in the hose your talking about but not much. Try pulling the hose off the connecter its attached to and move it around until you get the best angle before you reconnect it. That's what I did. :thumbs:
Old Jun 28, 2003 | 12:27 PM
Z06TheKid's Avatar
Z06TheKid
Default Re: Help with Blackwing install! (LS7)
How do you get the 90 degree fitting to come off the hose, I couldn't get it o slip off.
Old Jun 28, 2003 | 12:32 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
I went to NAPA and bought a straight connector to replace the 90 degree fitting. I believe the hose is the clean air supply line to the air pump.
Old Jun 28, 2003 | 03:31 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Help with Blackwing install! (itsonlyairandfuel)
I just taped the 90 degree bend to a short wooden dowel with black electrical tape. It's hardly noticeable but makes the connection much easier and more flexible.
CR555's Avatar
CR555
Another good solution is to connect the hose directly to the Blackwing. :D
Remove the elbow connector from the hose, take off its rubber grommet and slide it over the hose. Use some WD40 or silikon spray!
Old Jun 28, 2003 | 09:23 PM
LS7's Avatar
LS7
All I did was pull the fitting out of the factory air box and into the Blackwing. After the fitting, it goes to a curved hose which then went to a straight plastic adaptor which then went down into the front bumper somewhere. I just pulled the hose off the straight adaptor that connects the two hoses. I reconnected it to the straight adaptor after the Blackwing was in. :seeya
To Help with Blackwing install!
