I Need An LS1 Lesson!
Old Jun 30, 2003 | 02:10 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default I Need An LS1 Lesson!
Well, i've been spending a lot more time in the tech section lately, and I feel very comfy with some sreas of the car's design, but am spotty in some as well...particularly cams, heads,and anything on the inside of the engine.
Does anyone have a good link to learn about the LS1? Please don't just say read ls1.com. I'm looking for some articles which are written to learn the essentials and to get me up to date on understanding the mods available for different areas in about 30 minutes of reading.
Thanks in advance :cheers:
[Modified by BQuicksilver, 2:11 AM 6/30/2003]
Old Jun 30, 2003 | 04:31 AM
IFLUBYU's Avatar
IFLUBYU
Default Re: I Need An LS1 Lesson! (BQuicksilver)
It won't be your one-stop-shop for the all the info you are looking for, but I suggest you check out the following site and add it to your Favorites links:
http://www.ls1howto.com/
Good luck!
Old Jun 30, 2003 | 04:48 AM
BQuicksilver
Default Re: I Need An LS1 Lesson! (IFLUBYU)
Good luck!
That's a good one!! :cheers:
Old Jun 30, 2003 | 07:04 AM
Patches's Avatar
Patches
http://www.idavette.net/hib/02ls6/index.htm
And more info at http://www.idavette.net
Old Jun 30, 2003 | 07:59 AM
vstella's Avatar
vstella
I like this website!! Everything you would ever want to know about the LS1.. :yesnod:
http://www.ls1info.com/article.php?sid=88
Old Jun 30, 2003 | 07:55 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Go to Borders Books and get the book "LS1/LS6 The Corvette engine. and it will tell you everything you ever wanted to know about these motors and each and every part of it ie function/fit and results of most Mods.
Old Jun 30, 2003 | 08:22 PM
Face's Avatar
Face
Default Re: I Need An LS1 Lesson! (Roofless)
:iagree:
Old Jun 30, 2003 | 08:46 PM
davidfarmer's Avatar
davidfarmer
Default Re: I Need An LS1 Lesson! (Face)
here is an article I did
http://www.metricchemical.com/engine.html
Old Jun 30, 2003 | 09:49 PM
Bugster57's Avatar
Bugster57
Here's another....
http://members.***.net/roth/Holden_LS1.pdf
Let us know when you're ready to start tuning!
Old Jun 30, 2003 | 10:16 PM
AllCammedUp's Avatar
AllCammedUp
Default Re: I Need An LS1 Lesson! (davidfarmer)
David,
Great content in the article you linked to, but I had a real hard time reading the white text on the cornsilk background... I had to tilt the monitor several times as I scrolled just to get the text readable. Don't know if you did the web page design/coding, but if you didn't you might want to pass that on to whomever did. Thanks! :cheers:
Old Jun 30, 2003 | 10:21 PM
AllCammedUp
I didn't find this title at either amazon or borders. Do you have an exact title, author or ISBN? Thanks!
Old Jun 30, 2003 | 10:32 PM
Roofless's Avatar
Roofless
The percise title is: Corvette Chronicle ISBN Number0-7853-4314-8
Old Jun 30, 2003 | 11:21 PM
AllCammedUp
Most excellent. Thank you! :cheers:
Old Jul 1, 2003 | 12:19 AM
SHOWTIME!'s Avatar
SHOWTIME!
Please change the white lettering to something darker.
It's so hard to read
Old Jul 1, 2003 | 12:54 AM
Sam Lin's Avatar
Sam Lin
Default Re: I Need An LS1 Lesson! (SHOWTIME!)
If you can't read it, click and drag the mouse over it to highlight it in reverse contrast, makes it easy to read.
Sam
Old Jul 1, 2003 | 02:28 AM
wicked 98z's Avatar
wicked 98z
Default Re: I Need An LS1 Lesson! (Sam Lin)
Ls1tech.com
Ive learned alot form over there. Thats where i spend all my time at. But its slowed down alot. Not as much INFO going around like it used to
ALbert
Old Jul 1, 2003 | 02:47 AM
BQuicksilver
Default Re: I Need An LS1 Lesson! (Bugster57)
In about 3 years, once I'm done reading all the good info you guys provided. :cheers: :crazy:
To I Need An LS1 Lesson!
Old Jul 1, 2003 | 11:44 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
I have some good articles and links, including a brief i did a few years ago on how the pcm control system works. http://www.vetteguru.com
[Modified by kewlbrz, 10:45 AM 7/1/2003]
Old Jul 1, 2003 | 12:37 PM
CSC5's Avatar
CSC5
From: Yeah, well, you know, that's just, like, your opinion, man.
I can't seem to find this ISBN# anywhere, and when I do a search on the title, I get a couple different possibilities, none of which appear to be specifically about the LS1/LS6 engine. Am I missing something? Is the "Corvette Chronicle" a series or something?
Thanks.
Old Jul 1, 2003 | 05:33 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: I Need An LS1 Lesson! (CSC5)
Thanks.
I did a couple searches and couln't find it. :iagree: :iagree:
