My KR dilemma...continued...
Old Jun 30, 2003 | 02:22 PM
los7883's Avatar
los7883
Default My KR dilemma...continued...
Well I ordered the PACE LS6 descreened MAF and put it on yesterday...I made 6 runs and now I noticed that my LTFT's are way to positive. Before with the GMAFS and Mike's 2001 stock MAF at WOT I was at 0. Now at WOT I am showing +3 to +7 in my LTFT's in B1 and B2. My question is...I know I am supposed to change the MAF tables when switching from my GMAF to the stock one...could this be causing my LFTF's to be running positive instead of 0 or just below? I am still getting the KR with the new MAF but I'm assuming/hoping it is because I need to get everything dialed back in. Another question...why is it that when I put the stock MAF back in my LTFT's didn't change...but when putting in the LS6 MAF...my LTFT's shot up? Any ideas? Thanks.
Old Jun 30, 2003 | 02:49 PM
los7883's Avatar
los7883
Default Re: My KR dilemma...continued... (los7883)
I was doing some reading and showed that a high or positive LTFT reading suggests the PCM is trying to adjust for a lean condition. Would switching to the larger MAF cause me to now run lean...which would cause the KR? I'm hoping this is it and that all I need to do is adjust my Inj Flow Rate to bring it down?
Old Jun 30, 2003 | 03:16 PM
TLewis4095's Avatar
TLewis4095
Larger will result in lean condition...tune to match it.
Old Jun 30, 2003 | 03:28 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
You are on the right track Carlos, just decrease the Inj Flow Rate until the LTFT's are back in line. If you need me to make any adjustments to your tune give us a call and setup an appointment.
Old Jun 30, 2003 | 03:39 PM
SpinMonster's Avatar
SpinMonster
Default Re: My KR dilemma...continued... (Godspeed)
I originally adjusted the MAF table and I was getting 1514 codes all the time. I adjusted the table back to stock and then adjusted with the injector flow rate. All better now.
Old Jun 30, 2003 | 04:06 PM
los7883's Avatar
los7883
Default Re: My KR dilemma...continued... (SpinMonster)
With the new MAF...could it be that I am running leaner now...which is causing my LTFT's to be high due to the PCM trying to compensate by adding more fuel...also couldn't my new lean condition be causing KR to show up...
Old Jun 30, 2003 | 04:26 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
You know what is really funny?
I have an A4 with 3.42s, a SY 3500 as well and a Thunder cam (mine is the 2242/224 on a 114) and I have had pinging issues ever since I got heads and cam done.
My tuner said he installed a few TR cams and they all had pinging at low RPMs like mine does.
I have been adding toloune to each tank of gas which helps the pinging, but does not get rid of it. I have had it tuned several times with a dyno and LS1 Edit and still get the pinging. It may be the cam? :confused:
Probably I am going to try switching cams next year to see if that helps at all. I will be ready for a bigger cam by that time I think. :reddevil
Where in the RPMs does your car ping and how bad is it?
Old Jun 30, 2003 | 04:56 PM
los7883's Avatar
los7883
Default Re: My KR dilemma...continued... (2000^C5)
It looks like my KR is kicking in from 4300-5600 rpm's...usually don't get any from a roll, but from a stop it kicks in pretty good...so you think it's the TR cam?
Old Jun 30, 2003 | 05:35 PM
2000^C5's Avatar
2000^C5
I don't know, it may be, seems like a few people with the Tr cams are having pinging.
Is your pinging loud enough to hear?
Mine is... :cry
Old Jun 30, 2003 | 05:58 PM
chuckster's Avatar
chuckster
WHat does your IAT table look like?? Did you modify it?
If it's hot by you like it is by me...(95+) then iat temps alone could be causing the pinging...
Use the table to kill some timing above 95 degrees...
Here is what I did...
Starting at 95F (35C) I put these values down each column from 20kpa to 100kpa
35 ->
-1, -2, -3, -4, -5, -5.5, -6, -6.5, -7, -7.5, -8, -8.5
I got this from Robert Judd..
:smash: :smash:
Old Jun 30, 2003 | 06:10 PM
los7883's Avatar
los7883
Default Re: My KR dilemma...continued... (chuckster)
Before I did the decarb it was loud enogh to hear...afterwards it was gone but was still getting some KR. I didn't pay attention though...my IAT's used to be 120+ but after removing the fog surrounds they stay pretty low when making my runs...today they were kinda of high...all temps were below 98...pretty big change from 120* down to 98*. I don't have LS1 Edit yet...will need to save up for it...but will probably be going to LGM to have everything dialed back in to bring it up back to par. Is there any harm in driving the car if the LTFT's are high right now??? I''m assuming I am running lean right now...will it hurt the engine or will it only affect it at WOT???
Old Jul 1, 2003 | 09:09 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Did you ever end up trying out some Race Gas and watching your KR?
Old Jul 1, 2003 | 09:12 AM
chuckster's Avatar
chuckster
One more thing..I have NEVER seen an aftermarket MAF FIX K/R. In fact most of the time they cause it...
I'd go back to the Stock MAF descreened... Check your K/R again..
JMHO.. The MAF is a 20 min swap...
Old Jul 1, 2003 | 09:35 AM
VetteDrmr's Avatar
VetteDrmr
Carlos,
Considering that when we put on my stock MAF (with the screen, for everyone else) that the KR basically went away, I think I'd return the LS-6 MAF for a stocker. Then you can tweak the tables as necessary.
As far as damage is concerned, the PCM is able to compensate for the lean values (since you're not getting a code and Check Engine light), and the actual detonation is also being handled, I don't think you're endangering the engine.
Hope this helps, and have a good one,
Mike
Old Jul 1, 2003 | 07:46 PM
los7883's Avatar
los7883
Default Re: My KR dilemma...continued... (VetteDrmr)
Thanks guys...I am currently selling the Granatelli, contacted PACE to return their LS6 MAF, and am now looking for a used LS1 MAF. There is nothing wrong with the Pace or Granatelli MAF, from what they told me...their MAF's are calibrated for stock to semi-modded corvettes. They said it isn't calibrated for a Vette with the mods I have...to have Granatelli Motorsports recalibrate it would cost $125+...yea whatever...I am now in the market for a stock MAF if anyone has an extra one laying around...or if anyone is looking for a Granatelli or LS6 MAF... :cheers:
Matt...still haven't ran race gas through...when we put the stock MAF (Mike's MAF) back on the KR went away...I'll post a table of my run with the stock one back on. Give me a second.
[Modified by los7883, 11:32 PM 7/1/2003]
Old Jul 1, 2003 | 07:56 PM
los7883's Avatar
los7883
Here you go...just click on the table to enlarge it...
Old Jul 1, 2003 | 10:45 PM
chuckster's Avatar
chuckster
Something is really wrong..I know different years vary..But the most timing I saw you get without K/R is 19 degrees???
I have a 2000 and get clean 29 degree WOT...
Even with the Thunder Cam you should be able to get better than that. C5noir got 30 degree WOT with the 224/224 TR cam..
Who is flashing your PCM again? See if you can get a copy of the flash and post it..
Put the stock MAF on.
Fill her up with Racing Gas...
I swear you are running in the low octane table...
Also one more important thing...Show us your O2's during all that k/R... If you are running really lean you will knock yourself to hell...
[Modified by chuckster, 10:48 PM 7/1/2003]
To My KR dilemma...continued...
Old Jul 1, 2003 | 11:00 PM
los7883's Avatar
los7883
At the time I had it tuned we weren't sure what was causing the KR, it was 100*+ in the shop so we thought that could have been it...the timing was backed out to see if the KR would cut out some. 30* is doable but I want to get this KR out of the picture before I take it back to have the PCM tweaked.
With the stock MAF on we were running right at 0 for my LTFT's in B1 and B2. After I installed the PACE MAF my LTFT's went way too high +9. So yea...now I'm running real lean...So I'm selling my Granatelli...sending my PACE MAF back, and looking for a stock MAF...once I get a stock one...and the KR has gone down to <1* at WOT...I will put the race gas in to see if this fixes it for sure...if it does...then I will take it back to have the timing increased and the A/F tuned back in...by O2's are you talking about the voltages? What should I be looking for there?
Old Jul 1, 2003 | 11:01 PM
MattG's Avatar
MattG
I have to agree with chuckster. Something is up if you are on the verge of KR with 19 degrees of timing, which is probably in the low octane table.
Going to the stock MAF is a good next step.. Then you should be able to start adding more timing and see if the KR comes back, but you would need LS1edit to do so.
[Modified by MattG, 11:04 PM 7/1/2003]
Old Jul 1, 2003 | 11:03 PM
los7883's Avatar
los7883
Default Re: My KR dilemma...continued... (MattG)
If I am running super-lean right now won't this kick me into my lower octane table? I'm hoping this is the case...but I won't know for sure until I find a stock MAF...
[b]DOESN'T ANYBODY HAVE AN EXTRA ONE LAYING AROUND???[b]
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
