Oil pressure
Old Jun 30, 2003 | 08:00 PM
402Sam's Avatar
402Sam
Default Oil pressure
What is the normal pressure for our cars while at idle. usually mine is 35 then when I put it into gear it drops to sometimes 25. While driving it stays in the 35-40 range. Is this normal. :confused:
Old Jun 30, 2003 | 08:51 PM
davidfarmer's Avatar
davidfarmer
Default Re: Oil pressure (sprayedc5)
Slightly low, but still safe. See if it changes during your next oil filter change, as that sometimes effects pressure.
Old Jun 30, 2003 | 09:14 PM
LS7's Avatar
LS7
That,s O.K. :thumbs:
Old Jun 30, 2003 | 11:52 PM
mapman's Avatar
mapman
Specifications from 2003 Service Manual (p6-13)
Oil Pressure - Minimum - Hot
6 psig at 1000 engine rpm
18 psig at 2000 engine rpm
24 psig at 4000 engine rpm
Mine is around 40 psig at 2000 rpm. Seems like your car is well within sepcification.
Old Jul 1, 2003 | 12:49 AM
Jhubbard's Avatar
Jhubbard
Default Re: Oil pressure (mapman)
My car while hot, and in idle, get down to 29psi @ the lowest. While cold, i've seen it get to 60Psi
To Oil pressure
