cracked rotor
Old Jul 1, 2003 | 05:05 AM
C5 Frederik's Avatar
C5 Frederik
Default cracked rotor
This is a picture of a cracked Mercedes SL, 5.0l, rotor at 30k miles
Do not know if the wholes are drilled or casted. Just for your information. It seems to be a common affair.
Frederik
Old Jul 1, 2003 | 05:22 AM
Racer1x's Avatar
Racer1x
Default Re: cracked rotor (C5 Frederik)
Spacing of the holes don't look uniform, prolly a home drill project.
Old Jul 1, 2003 | 09:45 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
no radius
Old Jul 1, 2003 | 10:08 AM
Richin Chicago's Avatar
Richin Chicago
Frederik
Somebody should lock up their drill press and go home!
[Modified by Richin Chicago, 9:08 AM 7/1/2003]
extremecorvette's Avatar
extremecorvette
Did you have them done or are they stock or aftermarket?
Old Jul 1, 2003 | 10:41 AM
C5 Frederik
Default Re: cracked rotor (extremecorvette)
This is a stock rotor off a company car.
Frederik
Old Jul 1, 2003 | 10:56 AM
Richin Chicago
Frederik
They must have had the NC machine on "random" when they drilled it! :) :)
Old Jul 1, 2003 | 05:35 PM
C5 Frederik
Default Re: cracked rotor (Richin Chicago)
Don´t think so. Every second row of bores is the same. One row to the other has an offset.
But this is not the reason to show the pic: is there any drilled rotor that has no cracks?
Frederik
Old Jul 1, 2003 | 05:52 PM
Jim 47's Avatar
Jim 47
OK, I give up! Where is the crack??
Those little imperfections at the holes really can't be called cracks. When you get an opening running from the top of the rotor brake surface to the bottom, then you have a crack.
Old Jul 1, 2003 | 06:30 PM
Reeves's Avatar
Reeves
From: The inmates are running the asylum... San Jose, CA
Cracked?, not yet... this is what a cracked rotor looks like:
Remember kiddies, proper brake cooling is not a luxury on the track. :D
Reeves
Old Jul 2, 2003 | 02:44 AM
cmeflyby's Avatar
cmeflyby
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
those are definitely stress cracks and will continue to propagate until it looks like the rupture :eek: posted by someone else.
they are almost certainly not cast as there is no radius or even a chamfer at the edges, as someone else already pointed out...that is a no-no :crazy:
some junior mechanical engineer was thinking about his girlfriend when he did the CAD model for those rotors :rofl:
:cheers:
Old Jul 2, 2003 | 03:07 AM
User 81424's Avatar
User 81424
Frederik
No there is not, a friend and Pres of PCA over here is an engineer at Porsche and if was up to him there would be no more drilled rotors, just slots if needed.
Old Jul 2, 2003 | 08:26 AM
Richin Chicago
Default Re: cracked rotor (CPT Z06)
Frederik
I always cringe when some new person shows up at the track with bright shiny drilled rotors. Definitely something that should stay with the buff and shine crowd. My friend, who has a Z06, and is an excellent roadcourse driver, showed up with a set early this season. He should of known better but both rear rotors cracked early in the evening. He was lucky as the dealer took them back.
To cracked rotor
