Darned Dam Question
Old Jul 4, 2003 | 12:44 AM
blackjackdelta's Avatar
blackjackdelta
Default Darned Dam Question
I pick up my 2002 vert in two days. Driving my friends, everytime I back out of the driveway, I scrape the air dam. Are these things necessary for airflow or can I remove them and not hurt the car.
Old Jul 4, 2003 | 12:47 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Darned Dam Question (blackjackdelta)
They are needed to direct airflow into the radiator but don't worry they are made to flex and scraping is ok :cheers:
Old Jul 4, 2003 | 07:02 AM
MiamiDave's Avatar
MiamiDave
Default Re: Darned Dam Question (runamuk)
Designed for it. Cheap to replace also. Do NOT Remove them...
Old Jul 4, 2003 | 08:39 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Darned Dam Question (MiamiDave)
I know everyone on here SWEARS to NEVER remove the damn dam, but I did over two years ago and have never noticed a change in my temperatures, even when roadracing with my 436ci engine. When I first removed it, I had a heads/cam package and the stock radiator and there still was not a change in my temperatures when I was moving.
So contrary to popular belief, it makes no difference, or at least it did not for me.
Old Jul 4, 2003 | 09:06 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Default Re: Darned Dam Question (MattG)
:iagree: :thumbs:
Old Jul 4, 2003 | 12:39 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I doubt they would be on the car if they weren't neccessary.
Mine scrape sometimes on my driveway but as stated the outer 2 flex and the center one is spring loaded. They do direct the air flow.
Old Jul 5, 2003 | 02:10 PM
gpflepsen's Avatar
gpflepsen
Cruise-In II Veteran
Default Re: Darned Dam Question (2k2C5)
I thought another main reason for the front airdam was to work with the underbody and help the cd and get better fuel mileage. Well, at least I sleep well at night thinking that.
Old Jul 5, 2003 | 02:20 PM
USA Muscle's Avatar
USA Muscle
Yeah but look where you live !! It sure doesn't get as hot there as it down here in Texas !! :lol: 90 degrees @ 10:00 or 11:00 at night is not uncommon in the summer !
:eek:
Old Jul 5, 2003 | 03:31 PM
fast4vette's Avatar
fast4vette
they are necessary for airflow but made to scrape and cheap to replace. try this one time - instead of pulling in the driveway and backing out, back in the driveway and pull out. that cured my scraping at a particular driveway.
Old Jul 6, 2003 | 10:20 AM
MattG's Avatar
MattG
Default Re: Darned Dam Question (USA Muscle)
:eek:
Actually, we see quite a few 90+ degree days with VERY VERY high humidity. Mind you it is only for a few months out of the year, but this car has definitely been ran through hot weather, including doing roadrace lapping events in 90+ degrees.
I first removed the air dam when I was down in Bowling Green for Labor Day of 2001 because I hit a chunk of tire on the road and it got all bent up. The temperatures down there were very close to 100 with high humidity and that is why I was worried, at first, what the effects of me removing this air dam would be for the drive home. But I found there was no change in temperatures.
Remember that this air dam would have absolutely no effect when the car is at a standstill, and that is pretty much the only time you would ever have to worry about overheating. When you are moving, and air is flowing, even without the air dam, your car shouldnt be struggling to maintain a good operating temperature.
Old Jul 6, 2003 | 04:52 PM
larrysb's Avatar
larrysb
The air deflector does help direct airflow into the radiator. It's not absolutely essential that it be there. It does help running at low speeds, like in-town traffic 25-30 mph. I'm told that it also helps to break a vacuum at very high speeds.
I know people who have taken it off completely and not noticed any terrible effects.
Dang vette doesn't get much airflow anyway, needs all the help it get. But if it bothers you, take it off.
To Darned Dam Question
