Help with my DIC
28-TCS
C1255H(EBTCM internal malfunction) What is the EBTCM?
C1281H(Steering sensor uncorrelated Malfunction)?
A0-LDCM(LOSS OF COMM WITH DCM)
A1-RDCM(LOSS OF COMM WITH DCM)
C1255 - a malfunction has been identified within the EBCM - Electronic Brake Control Module. A scan tool will probably be necessary to run additional tests.
C1281 - a problem exists with the Vehicle Stability Enhancement System (VSES) As you did not indicate codes C1282,C1284, or C1287 were also set, that would indicate C1281 was set when the VSES is engaged for 10 seconds with the delta velocity error always in either understeer or oversteer.
A0-LDCM(LOSS OF COMM WITH DCM) LDCM-Left Door Control Module
A1-RDCM(LOSS OF COMM WITH DCM) RDCM - Right Door Control Module
These loss of communication errors might indicate a poor ground or corrosion on connectors.
