Stalling during braking in neutral-large cam issue
Old Jul 5, 2003 | 02:10 AM
SpinMonster's Avatar
SpinMonster
Default Stalling during braking in neutral-large cam issue
For those that have a dropping idle during a brake in neutral and have gone to a really big cam, the cam may not be letting you produce enough vacuum during braking while stopping in neutral especially after a big RPM run-up. A solution could be this vacuum reserve canister from crane cams to address that problem or if you stall and lose braking power. $45 bucks for added safety is ok in my book....stay safe.
http://www.jegs.com/cgi-bin/ncommerc...03&prmenbr=361
Old Jul 5, 2003 | 02:12 AM
SpinMonster
Default Re: Stalling during braking in neutral-large cam issue (SpinMonster)
and no i didn't enter this post 3 times!....all the same post time.....puters
Old Jul 5, 2003 | 06:34 AM
rwj383's Avatar
rwj383
what are the specs of your cam and motor? I would be interested since i've had really good luck at tuning oscillating/stalling idle of wild cams just using Edit. No guarantees, though. Let me know.
Old Jul 5, 2003 | 12:19 PM
SpinMonster
Default Re: Stalling during braking in neutral-large cam issue (rwj383)
Thanks. Mine is running great. I was just thinking it would be a nice back-up for safety.
To Stalling during braking in neutral-large cam issue
