2000 Corvette - Intake / Bridge -- Donaldson
Mods that I am looking at: Prices are from the Corvette Mall.
C5 Blackwing Filter Assembly - $ 215.00
C5 Power Duct - $ 152.10
C5 Power Coupler - $ 62.99
I would greatly appreciate any input / suggestions.
Regards,
Mark
[Modified by mdhmi@yahoo.com, 3:56 AM 7/11/2003]
[Modified by LS7, 3:11 AM 7/6/2003]
[Modified by LS7, 3:14 AM 7/6/2003]
[Modified by LS7, 3:15 AM 7/6/2003]
On a different topic entirely - can someone point me to a good article / post on racing your Vette for the first time? When you should shift (6 speed), tire pressure, how much gas you should have in the tank (1/2 tank is what I have read), etc, etc. That would be great. Thanks again everyone for helping a newbie.
Mark
I have an automatic so I just flat punch out of the hole with Traction control off. It really doesn't spin the tires that bad. I just let the car redline each gear after that.
I run 31 lbs. of pressure in the tires which goes up to 33 lbs. driving around.
I think going with the LS1 Edit for around $300 is worth it to tweak out the engine. :flag :seeya
Another thing to consider is getting rid of the factory GM battery.
They are known to leak acid and the computer and wiring harness are right under the battery. If it leaks , you usually don't find out until you start experiencing electrical problems. Then you really have a nightmare on your hands and a cleaning job to take care of.
Mine didn't leak, but I wasn't going to wait for it to start.
I bought the Optima Redtop for $130. It comes out to $135 but you get $5 back when you return your old one. You can get it at Auto Zone or Pep Boys. It's a Gel battery so it won't leak. :thumbs: :thumbs:
[Modified by LS7, 12:53 AM 7/7/2003]
Go for the exhaust and xpipe (you will love the car even more), and then with an LS6 intake manifold (looks same as stock, just a bigger plenum). Between that and letting Carmen and Dennis tweak it with LS1-Edit, you should be low in the 13's, get rid of the EMTs and with some practice you will be working your way down to 13 flat, with a very streetable coupe, but with a much better sound. :thumbs: FYI: If you plan on running it at the track regularly, save up for a new clutch, the LS6 clutch is not a bad way to go when you have to. $600ish DYI, $1000-$1300 installed.
:skep: Your FRC is a bit lighter than a coupe and your HP, if stock, is quite a bit above factory normal, though it is not impossible that a rare one or two will be +10% over the factory rating. Driver ability can account for quite a bit of difference, but not THAT much, maybe .2-.3 tops. Your e/t numbers indicate more like 314-321rwhp, and thats with you/gear/fuel only weighing in at 150 total. The chance of doing this on EMTs even if they are lowered to 25psi with a brutal burnout, IMHO is incredibly low, much less duplicable on a coupe.
To many people just want to throw money and parts at their cars and then just expect low ET's out of them only to come back from the track wondering why they are still in the 13's. PRACTICE is where you will find the most gain's.
2. Your mods are going to add up to more than 20-25 rwhp, and have ceased your "street legal" status, especially in CA, which moves this completely off
the original thread.
3. If you don't think 125lbs is much of a diffference, you haven't been draggin' long. Any dragger would do anything short of turning tricks to get rid of 125#s. Try doing your runs with someone in the passenger seat and see what the difference is.
4. I was right on the money on your weight (I figured 3117+150~same), tire pressure and burnout, and yes, 8-9 seconds is brutal for high-performance street tires, but agreeably good drag strip practice and the right thing to do for quick 60' times, but only if you were born rich and can afford new EMTs every year.
5. If you practice as regularly as you say, I seriously doubt you are still working on the original clutch, or are close to kissing it goodbye.
6. Your last two posts contributed nothing to the original thread. Let's not hi-jack this thread. If you want to carry this on, IM me or e-mail me, please.
7. On the weekend of august 8.9.10 I will meet you at any track within 300 miles of whatever the midpoint between Wash, DC and Sacramento is. After 2 runs for orientation, I will bracket race you for three runs, best two out of three wins, loser coughs up 500 yards to the winner and washes the rubber off his quarterpanels. No BS- that is a straight up offer, we can work out the details.
As to the original thread, please forgive the sidetrack!
I should also mention that changing the tires from EMTs will also lighten the vehicle by 3-4 #s per tire. (- the can of fix-a-flat you will want to throw in)
PS - I have new runflat with less than 1000 miles. :crazy: :yesnod:
I ordered the Blackwing and hood seal this afternoon from http://www.exit28motorsports.com/ . The Blackwing was shipped this afternoon and should arrive by this Friday. I'll probably submit a review next week. As for the earlier suggestion on the LS1 Edit - that sounds worthwhile and I have made a new post in the Scan and Tune section requesting information on a local (Michigan) tuner.
Thanks again everyone,
Mark
On the purchase decision, good pick on the Donaldson. You can't go wrong. I would suggest the cold air cover instead of the hood seal. But that's just me, and all the other guys who run them ;)
I'm not a dragger/bragger :) only done it at the Cruise In II. After a few runs I was running high 12s @ 112-113 mph. Never dynoed but I know my 99 FRC when matched up with other guys with similar mods (Donaldson and PRT's) is near top of the class in HP #'s
I've been to 170 a few times and the speed comes slow after that. Don't know where it'd stall out.
[Modified by gpflepsen, 9:05 PM 7/7/2003]
Thanks again everyone for being patient with a newbie,
Mark
Mark
Check out the Drag Racing forum, you should find lots of goodies in there.
Have a good one,
Mike
Regards,
Mark
