Vararam Installation Problem ?
Old Jul 6, 2003 | 06:52 PM
HP_Addict's Avatar
HP_Addict
Default Vararam Installation Problem ?
Guys I installed a Varram on my 2002 coupe today. Did anyone have trouble getting the fog light ducts to line up. After installing the ducts supplied with the kit, my fog lights do not line up with the holes in the black duct housing. The ductwork appears to be about 1/2 inch low. I tried various combinations of spacers and ended up with 0 on the outside, 1 on the inner upper and 2 on the inner lower. It looks like the entire "V" air ducts need to raise up a couple inches in the rear resulting in a slight rise in the front around the fog lights. However this forces the MAF, air bridge and coupler to not rest on the radiator shroud any longer. The rest of the system is all stock parts. Is there a way to fix this problem or should I just leave it. If I leave it when the fog lights get hot will they melt the plastic.
Thanks for the help.
Old Jul 6, 2003 | 08:33 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Default Re: Vararam Installation Problem ? (marlowchris)
Call Patrick @ Vararam. I called him on a friday night after getting stumped on my install, after a few he had me back on track. I believe that his telephone number is on the instructions.
Old Jul 6, 2003 | 09:14 PM
HP_Addict's Avatar
HP_Addict
Default Re: Vararam Installation Problem ? (Dugmole)
I have no numbers or contact information on my instructions, do you still have his number?
Old Jul 7, 2003 | 07:29 PM
Dugmole's Avatar
Dugmole
1 866 507 2648
Old Jul 8, 2003 | 11:00 AM
extremecorvette's Avatar
extremecorvette
Patricks office phone 713-899-6456
Old Jul 8, 2003 | 10:00 PM
99 The Hard Way's Avatar
99 The Hard Way
Default Re: Vararam Installation Problem ? (extremecorvette)
My hardtop didn't come with fog lights, but my air bridge also does not rest flat on the shroud. It won't snap back into the rubber nubs. I just left it, and have no problems. That would bother me if it was not aligning with my fog lights. Hopefully they will get you straight. I just bought a used airbridge & coupler, so I may try to adjust it better when I install the airbridge. SCOTT
Old Jul 9, 2003 | 02:27 PM
HP_Addict's Avatar
HP_Addict
I talked to one of the guys at Varram. He said that with the proper shims the lights, should line up. I am going to tear it apart and try shimming it differently. Also he said that Vararam is coming out with a new coupler deisgn to work with their intake and it has shown impressive numbers. So anyone in the market for a coupler and airbridge, might want to wait about a month.
Thanks for the help guys.
To Vararam Installation Problem ?
