Instrument Cluster Lights do not turn off
Old Jul 9, 2003 | 12:28 PM
tpocock's Avatar
tpocock
Default Instrument Cluster Lights do not turn off
I have a 2003 Z06. The original Delco battery just went bad, so I replaced it with an Optima Yellow top. But when I went to check on the underlying current drain, I found that the instrument panel lights do not go off even when the key is removed and the alarm system is armed.
Has anybody had this problem?
Old Jul 9, 2003 | 12:48 PM
Soldiervette's Avatar
Soldiervette
Default Re: Instrument Cluster Lights do not turn off (tpocock)
well 2003 Z06 i will not mess with it i just take it to the dealer for new battery and complete check up, does this words means anything to you?
WARRANTY!!!!
GL partner :flag
