Misfire Code P0300
Old Jul 10, 2003 | 09:00 AM
steveNY's Avatar
steveNY
Default Misfire Code P0300
I own a 2000 coupe and decided to have headers, cats, new sparkplug wires, & plugs installed (40K miles). The car worked fine before, now I'm getting a
check engine & misfire code. The garage swears all the engine cylinders are firing they claimed to have hooked it up to a computer. While idling the car RPM's seem to drop real low, while driving you can hear pop & crackle out the exhaust. Any Ideas? If they damaged a O2 sensor could that do it? Any other idea's?
Old Jul 10, 2003 | 10:51 AM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: Misfire Code P0300 (steveNY)
Common code after headers. Could possibly have a bad wire or plug. Burning a wire after headers is common too. The gurggle and pop (unless really loud like a backfire) is common too. Check those wires!!!!!!
A re-tune isn't a bad idea either to maximixe the mods......air/fuel may need some adjusting.
Old Jul 10, 2003 | 11:12 AM
mapman's Avatar
mapman
..... damaged a O2 sensor could that do it? ....
The HO2S reports a rich or lean condition, it doesn't cause the condition. The P0300 is just reporting what you are hearing, that is a misfire condition, in the case of P0300 it is a misfire rate sufficient to cause emission levels to exceed mandated standards.
Old Jul 10, 2003 | 06:32 PM
CJS's Avatar
CJS
I got that code after heads, cam and headers. At first it was everyday, then it went to every week, then to once a month. Can't explain why, this all happened before any tuning. I made no changes to the car, it just fixed itself.
Old Jul 10, 2003 | 10:34 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Your idle could be too low, after my cam installation I got the misfire code. I had to rasie my out of gear idle to 775 and the in gear idle to 825, all is well.
Old Jul 14, 2003 | 09:47 PM
steveNY's Avatar
steveNY
Default Re: Misfire Code P0300 (Buckmaster)
Thanks for the help! I will start with having the wires & plugs checked first. My problem is, I don't know of any Corvette specialty shops in upstate NY.
To Misfire Code P0300
