MSD wire resist.?
Old Jul 10, 2003 | 04:32 PM
88sk's Avatar
88sk
Default MSD wire resist.?
just got my 8.5 MSD plug wires& put an ohmmeter on them,6wires were at 29 ohms,1 was 34ohms,1was 46 ohms,is this ok ?
Old Jul 11, 2003 | 01:32 PM
THRAP 42's Avatar
THRAP 42
Default Re: MSD wire resist.? (88sk)
88sk,
According to their website - yes.
8.5mm Super Conductor Spark Plug Wire
Features:
Only 40 - 50 Ohms resistance per foot.
Figure the wires are less than a foot long so you're in the ballpark, IMO.
later,
[Modified by THRAP 42, 12:32 PM 7/11/2003]
Old Jul 11, 2003 | 02:55 PM
88sk's Avatar
88sk
Default Re: MSD wire resist.? (THRAP 42)
I was worried about the 46 ohm wire since its 7"long &not 12",but dont know how much more resistance there would be if it were 12".
Old Jul 12, 2003 | 02:53 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There may be a few additional ohms added because one of the connectors at one end or the other is not on as tight as the rest. I would not worry about.
I need wires too. 6 of my stock wires measured around 300ohms. I thought that was good for a car with 60,000 miles until I measured the other two wires. The other two read 1.2 meg ohms and 3.7 meg ohms. The weird part about it is the engine still runs like a champ all the way to 6200 rpm! :D
I KNOW that wont last long before they start to break down.
Now I am batteling over getting a set of Magnacore wires or the GM performance wires.
Your few ohms of difference should NOT be a problem. :thumbs:
Bill Curlee
Old Jul 12, 2003 | 04:33 AM
88sk's Avatar
88sk
Default Re: MSD wire resist.? (Bill Curlee)
thanx ,I checked my stock ones & they were high as well,the msd should be alot better.
Old Jul 12, 2003 | 06:18 PM
Still_Single's Avatar
Still_Single
I'm putting on new MSDs right now too - here's my stats:
MSD - ohms range from 27.7 to 31.4 / avg is 30.1
stock - ohms range from 309 to 325 / avg is 318 (11,000 miles)
My wires were fine - the plat. pucks on my plugs were gone - so I just went ahead and replaced the wires at the same time.
The MSD's are definitly lower resistance!
Old Jul 13, 2003 | 11:05 AM
chocoholic's Avatar
chocoholic
For an explanation as to why the low-voltage DC resistance is not what's important, go here: http://www.magnecor.com/magnecor1/truth.htm
To MSD wire resist.?
