problem with your catalytic convertors. may be time for new cats. you running stock cats on the car? i'd first just try to clear/reset the codes. if they come back after 5-6 resets, then i'd actually take a look at the cats. good luck, and keep us posted on what you find.
Okay do you think this could be because I didnt install the cats when I did the main mod...lol. One was FLP headers and X-pipe. I chose not to run with the cats. Guess maybe I need to install them.
I heard I can use O2 sims and it will eliminate my issue...What would you do??
Okay do you think this could be because I didnt install the cats when I did the main mod...lol. One was FLP headers and X-pipe. I chose not to run with the cats. Guess maybe I need to install them. I heard I can use O2 sims and it will eliminate my issue...What would you do??
MY2KC5,
If you didn't install the CATs and went with the FLP off road pipes you MUST install O2 SIMS to conteract the missing CATs. Other option is install the CATs as you mention. I'm running the FLPs with CATs and O2 sensors without any problems.
