Belt Squeak Finally Fixed!!
Old Jul 11, 2003 | 08:20 AM
FZovko's Avatar
FZovko
Default Belt Squeak Finally Fixed!!
After three months the vette is no longer squeaking. The squeaking would stop after running the car for about 15 minutes. It would also squeak at full throttle.
Things that didn't work:
- First, I applied belt dressing (don't do this made it worse)!
- Second, dealer replaced the ac and serpentine belts with OEM belts
- Third, replaced tensioner and idler pulley
Finally the fix:
- Removed OEM belts...used simple green on all belt surfaces...scrubbed with brush.
- Replaced OEM belts with Goodyear Gatorback!
I had some problems with the ac belt replacement. I needed a friends help with this one. He was under the car with a wrench on the ac tensioner while I slipped on the belt from above. It was very hard to get a wrench on the tensioner belt from above. Otherwise, a very simple maintenance job. I should have done it the first time and saved myself $150 :mad
But now its :party: time.
Hope this helps someone with the same problem.
Old Jul 11, 2003 | 08:32 AM
VetteDrmr's Avatar
VetteDrmr
Default Re: Belt Squeak Finally Fixed!! (FZovko)
Thanks for the info. I've got the same symptoms you do, just haven't got around to fixing it. Sounds like a set of gatorbacks are in my future.
BTW, when you say you used simple green on all belt surfaces, was that the metal surfaces you're referring to? Also, was that to get rid of the belt dressing mess?
Thanks, and have a good one,
Mike
Old Jul 11, 2003 | 03:46 PM
FZovko's Avatar
FZovko
Default Re: Belt Squeak Finally Fixed!! (VetteDrmr)
I used Simple Green on all pulleys after removing the OEM Belts and scrubbed with a toothbrush. Then I rinsed with water. Hope this helps.
Old Jul 11, 2003 | 04:55 PM
VetteDrmr's Avatar
VetteDrmr
Ok, that's what I thought, but wanted to make sure.
Mike
Old Jul 11, 2003 | 06:13 PM
SnowyATX's Avatar
SnowyATX
On a related note....recently I installed an underdrive pulley and the required new belt sizes. When the change was complete my squeek was gone as well. A benefit that I wasn't expecting. Not sure why it stopped by hey...I'll take it. :D
Old Jul 12, 2003 | 12:20 AM
luv2golf's Avatar
luv2golf
Default Re: Belt Squeak Finally Fixed!! (PewterC5)
Please discribe your squeak. I'm getting a squeak when I first take off from a dead stop. Is this what your hearing?
Old Jul 12, 2003 | 11:56 AM
sbkim's Avatar
sbkim
Is the idler pulley the big round one in the middle of the engine. I have an automatic and looks near impossible to get to...
Old Jul 12, 2003 | 05:15 PM
Killrwheels's Avatar
Killrwheels
Default Re: Belt Squeak Finally Fixed!! (sbkim)
Whats the belt number of the Gatorback to match factory belt and factory tensioner ??
Old Jul 13, 2003 | 12:10 AM
FZovko's Avatar
FZovko
Default Re: Belt Squeak Finally Fixed!! (Killrwheels)
4060802 Serpentine belt
4040420 AC belt
Old Jul 13, 2003 | 12:12 AM
FZovko's Avatar
FZovko
Default Re: Belt Squeak Finally Fixed!! (luv2golf)
I noticed mine on idle more severe at acceleration...after about 15 minutes the squeak went away. Very annoying!! :mad
Old Jul 13, 2003 | 11:19 AM
Killrwheels
where did you purchase, a forum vendor ?? Goggle cannot seem to track one.
**also Goodyears site shows that all Corvettes use 4060798 and by the belt number thats 79 inches and 8/10's of an inch wide , your using a belt only 2/10's of a inch wide on the altenator ??
[Modified by Killrwheels, 11:44 AM 7/13/2003]
Old Jul 14, 2003 | 03:32 PM
99inDenver's Avatar
99inDenver
Not sure what these guys are hearing, but mine just started to squeek / whine if you keep the brake on and put it in drive or reverse. Sounds like a belt, but it goes away if you put it in neutral.
Can't tell if it make any noise while driving. Can't hear it over the road noise.
To Belt Squeak Finally Fixed!!
