Does rear end gers affect RWHP?
Old Jul 12, 2003 | 10:27 AM
hubes's Avatar
hubes
Default Does rear end gers affect RWHP?
If so how?
EDIT: oh no i spelled gears wrong in the title, can a mod fix that, thanks
[Modified by hubes, 10:27 AM 7/12/2003]
Old Jul 12, 2003 | 11:28 AM
Killrwheels's Avatar
Killrwheels
Default Re: Does rear end gers affect RWHP? (hubes)
quarter mile times, and spirited take-offs from stoplights ! Keeps the car in its powerband (rpms) with numerically higher gearing ratios. More effective at using the horsepower you have :thumbs:
Old Jul 12, 2003 | 11:52 AM
Topless's Avatar
Topless
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06-'07-'08
Default Re: Does rear end gers affect RWHP? (Killrwheels)
But no, it doesn't actually change the amount of horsepower. It just feels that way. :D
Old Jul 12, 2003 | 12:43 PM
jmX's Avatar
jmX
Default Re: Does rear end gers affect RWHP? (Topless)
Yes, it will change RWHP reading. Higher gear ratios usually consume a little more power before it makes it to the wheels. I honestly don't know the science behind it, but I beleive its due to more friction and the fact you are spinning stuff up faster (fighting against more rotational inertia?).
I dont think its more than a few rwhp difference you're talking about so its not anything to worry about.
Old Jul 12, 2003 | 12:52 PM
Oyea's Avatar
Oyea
Default Re: Does rear end gers affect RWHP? (jmX)
I'm pretty sure it doesn't change RWHP, but does give you more RWTQ.
Old Jul 12, 2003 | 01:17 PM
Mitch C's Avatar
Mitch C
Default Re: Does rear end gers affect RWHP? (Oyea)
:iagree:
You don't actually loose any HP when you go to a numerically higher rear. The dyno just gives a lower reading with big gears.
Old Jul 12, 2003 | 02:41 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Does rear end gers affect RWHP? (Mitch C)
No, it doesn't. From the email I got from Paul at Tazzo (the performance meter), he says that instant hp is calculated by weight x acceleration x speed. The higher gear ratio increases acceleration but it happens at a lower speed and these offset each other in the measured calculation. He has some interesting observations, especially how professional racers look at things. For instance, he said that they don't look at the maximum horsepower but instead, when tuning a car, they try to minimize the time between two rpm points. His performance meter also measures average horsepower between two points because it tells what is happening over the entire powerband, not just at one point in time.
On another post long ago there was a lot of input on this subject and I think the final conclusion was that going from 3.42 gears to 4.10 gave a 20% increase in thrust, which would give a "virtual, though unmeasured" 20% increase in horsepower. In other words, you would get the effect of 20% more horsepower but would be unable to measure.
In the end, though, the 4.10's are just a kick in the pants, and for me, that's half the fun.
Hope this helps.
Old Jul 12, 2003 | 04:31 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
St. Jude 15 Year Donor
Cruise-In V Veteran
St. Jude Donor '08-'25
:iagree: Will not change actual rwhp or rwtq, however when measured on a 6 speed transmission the "calculated" rwhp loss is 15% with the stock 3.42 gears. With 4.10's the reading will show more like a 18 - 19% loss even though you are actually not losing anymore.
Old Jul 12, 2003 | 05:00 PM
Dope's Avatar
Dope
Resident moron
You will drop a few rwhp on the dyno, that has been proven approximately 2 billion times. If that answers your question.
Dope
Old Jul 12, 2003 | 05:43 PM
CJS's Avatar
CJS
If the question is "Do different gear ratios affect the MEASURED rwhp on a dyno?" Then I believe that the answer is Yes they do!
If a 3.42 ratio was used for a pull on the dyno, and then the gears were quickly changed to a 4.10 ratio, then I believe the new dyno reading would be 5 to 10 rwhp LOWER than before.
The engine hp did not actually change however. It is lower only because of the way the dyno measures rwhp. The 4.10 gears allow the dyno drum to be spun up to speed in less time, and this causes the rwhp reading to be slightly wrong (lower) compared to the 3.42 reading.
So it is just like doing the dyno run in 3rd or 5th, you will not get the correct reading.
Old Jul 12, 2003 | 07:08 PM
AFVETTE's Avatar
AFVETTE
Default Re: Does rear end gers affect RWHP? (CJS)
So then a car with base gears 2:73 would show more RWHP than higher numerical gears - if I understand your logic?
Tom
Old Jul 12, 2003 | 07:15 PM
hubes's Avatar
hubes
That was the question, and that was a very good answer. It's good to know that they won't change the measured HP by very much.
Old Jul 12, 2003 | 08:57 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I lost 10 rwhp reading on the dyno by going from the 3.42's to the 3.73's. I am not sure if the much higher stall Tq Converter had any influence.
[Modified by wallstAL, 11:19 AM 7/13/2003]
Old Jul 13, 2003 | 04:16 AM
camarodoctor's Avatar
camarodoctor
I ♥ My Corvette
How can you possibly change RWTQ and not RWHP? They are mathematically related. At any given RPM, if RWTQ is higher, RWHP will also be higher. Any loss is RWHP due to gears would be constant (i.e., proportional to the gear RPM) across the powerband.
gregg "engineer"
'01 Z06 (354 rwhp)
To Does rear end gers affect RWHP?
