New Shift knob problem on Hurst
Old Jul 15, 2003 | 09:55 PM
Hirohawa's Avatar
Hirohawa
Default New Shift **** problem on Hurst
Just got a Billet 6 Speed chrome ball today. But I can't get the shift pattern to lign up. There is an included hex nut, so the problem is that without the nut the 6 spd pattern is upside down. With the hex nut it is off by about 45 degrees.
What should i do?
Was this shift **** not made for the Hurst? Should I buy another length hex nut?
Any help would be greatly appreciated.
Steve
Old Jul 15, 2003 | 09:59 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: New Shift **** problem on Hurst (Hirohawa)
Are you saying you can't hold the **** in the correct position and tighten the lock nut? :confused:
Old Jul 15, 2003 | 11:14 PM
CCrane65's Avatar
CCrane65
I have the same ****. Back the **** out about 1/2 turn then tighten the hex (jamb) nut against it.
Also, please do not try anything more involved than this. It only gets tougher on a Vette.
Old Jul 15, 2003 | 11:26 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: New Shift **** problem on Hurst (CCrane00)
:rofl: :rofl: :lolg: :lolg:
Old Jul 15, 2003 | 11:32 PM
dfwroadkill's Avatar
dfwroadkill
St. Jude Donor '07-'09
CCrane00:
:lolg: :rofl: :lolg: :rofl: :D :D :D
Old Jul 15, 2003 | 11:33 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You might not want to try to solve any more math questions either. 45 degrees=1/8 turn. :jester
:cheers:
Old Jul 16, 2003 | 01:29 AM
bowtie racing's Avatar
bowtie racing
Lets sue hurst! :lol:
Old Jul 16, 2003 | 03:31 AM
Hirohawa's Avatar
Hirohawa
I installed the Hurst as well as the GAuge bezels trim kit. I thought this would be a breeze.
Will try this method.
Steve
Old Jul 16, 2003 | 03:47 AM
Hirohawa's Avatar
Hirohawa
Just did it took all of 30 seconds. I tried this earlier with pliers and now I used a wrench. Feel stupid because it was so easy.
This **** seems to get really hot even at night. Is this a problem for anyone who drives their car alot?
On to my next dileema - How do you know when the car is low on Fuel? ;)
Old Jul 16, 2003 | 07:08 AM
Patches's Avatar
Patches
An aftermarket shifter like the Hurst can transmit more heat from the tunnel because it has no isolator like the stock shifter so heat is conducted more directly through the metal shaft. I have found that sealing up the area around the base helps.
Old Jul 16, 2003 | 01:04 PM
Hirohawa's Avatar
Hirohawa
Default Re: New Shift **** problem on Hurst (Patches)
Patches
How do you seal it up?
Steve
Old Jul 16, 2003 | 02:12 PM
liv2ryd's Avatar
liv2ryd
The engine becomes very quiet and unresponsive to pressure on the accelerator pedal. :lolg: :lolg: :lolg:
Old Jul 16, 2003 | 02:19 PM
Patches's Avatar
Patches
I'll have to take a picture to post so it's clear. How I did it: Basically, you cut about 40% off a tennis ball and then put a hole about 5/8" in diameter in the top-center. Force it over the shifter shaft and securely down onto the base. Works great on mine.
Old Jul 16, 2003 | 07:32 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
:lol: :lol: :lol: :lol:
We all started somewhere take the ribbing as fun. ;) :thumbs:
Old Jul 16, 2003 | 07:43 PM
Radiant Heat's Avatar
Radiant Heat
Stop, turn the engine off, open the hood, locate the yellow circular handle (very close to the cap that says "Mobil 1"), pull the yellow handled "dipstick" out... if the fluid line is in the "ADD" section, then you're running low.
Old Jul 16, 2003 | 10:43 PM
Lancer033's Avatar
Lancer033
Default Re: New Shift **** problem on Hurst (Radiant Heat)
:skep: I'm not saying that i'm an expert mechanic or anything, but i'm pretty sure that's how you check the oil not the fuel. but what do i know
Old Jul 16, 2003 | 11:13 PM
dfwroadkill
Patches:
:yesnod:
Hirohawa:
Now that's a good sport and I give him credit for trying. You never learn if you don't ask and you don't do it. Onward through the fog, you'll get there.
:thumbs: :steering:
Old Jul 17, 2003 | 04:52 AM
Hirohawa's Avatar
Hirohawa
Default Re: New Shift **** problem on Hurst (dfwroadkill)
Will try the Tennis ball mod. Thanks for all the help. The ribbing is funny as well. I love this board!
:cheers:
To New Shift knob problem on Hurst
