Tire sensors compartibility question
Old Jul 16, 2003 | 04:45 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Tire sensors compartibility question
Will tire sensors work all C5's?
Or will the 2000's sensors are not compartible with 2002's?
:cheers:
Old Jul 16, 2003 | 05:48 PM
Purerock105's Avatar
Purerock105
Default Re: Tire sensors compartibility question (mike76002)
I believe you need the specific sensor to your model year.
There was a slight change in the size of the sensor, but I can't
remember what year. If you already have sensors, they should
work on most wheels, but not all.
:cheers:
Old Jul 16, 2003 | 05:54 PM
0Vette Stripes
Former Vendor
Default Re: Tire sensors compartibility question (Purerock105)
:cheers:
So it is the wheel issue not the computer issue?
If that is the case then I don't have to worry much since the sensors are in Y2K wheels and now I will put them on Z06 wheels.
Anyone else?
:cheers:
Old Jul 16, 2003 | 06:03 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
There are 2 style sensors, 97-00 and 01-04.
They operate on different frequencies I believe, and aren't intechangeable. You need to stay with the same style sensor you have now.
They are slightly different physically, the newer ones are slightly smaller overall, but they will all fit into the same wheels. Another difference is the new style sensor has a thick stepped rubber washer for sealing against the wheel, and the old style uses an O-ring. To mount the old style sensors into newer wheels, such as Z06 wheels, the new style washer should be used. You can probably pick the seals up at a dealer's parts counter, not sure.
:cheers:
To Tire sensors compartibility question
