Sound Deadner
Old Jul 16, 2003 | 09:09 PM
Salty's Avatar
Salty
Default Sound Deadner
Has anyone used any type of sound deadner in there car. While I love the sound I also like to roll up the windows and speak on my phone since I use the car for business. Thoughts ideas? :confused:
Old Jul 16, 2003 | 09:13 PM
TimC5's Avatar
TimC5
Default Re: Sound Deadner (Salty)
:seeya
http://mikemercury.home.att.net/sound.htm
Old Jul 16, 2003 | 09:52 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Sound Deadner.............DIVORCE!!! Sorry, couldn't pass it up. :yesnod: :lol: :lol:
Old Jul 17, 2003 | 12:29 AM
B1Mario's Avatar
B1Mario
I have some dynamat extreme under the carpet in the trunk, over the wheel wells and behind the seat. Over the wheel wells produced the most decrease in sound. I don't have any decible numbers to back it up, but I did notice a seemingly quieter highway ride. I have thought about adding it to the doors but haven't gotten to that yet. I have never had any of the "asphalt" scent I've heard others complain about. I went with the extreme to avoid any temp problems, plus it's easy to install.
Old Jul 17, 2003 | 11:27 AM
Mike Mercury's Avatar
Mike Mercury
Default Re: Sound Deadner (B1Mario)
dynamat extreme is good stuff. a little on the heavy side and somewhat costly to us cheap bastiches :)
If one has a high-powered stereo or a loud aftermarket exhaust; the dynamat extreme may be needed since it is denser.
:cheers:
Old Jul 17, 2003 | 11:38 AM
brianw21's Avatar
brianw21
Skip the frost king...... get the real stuff. If you ask in the audio forums, many have tried the frost king and were not satisfied. This on the otherhand will knock it down 9db or 8 times quieter.
http://www.hometheaterhifi.com/volum...ng-6-2003.html
Old Jul 17, 2003 | 12:00 PM
KingTut's Avatar
KingTut
Default Re: Sound Deadner (brianw21)
Do a search on articles by "Evil-Twin" he was the originator of this mod and his material was two sided aluminum foil with small buble wrap inbetween. It was carried at Lowe's and worked well. Maybe 1/4 " thick but very effective for sound and at no extra charge, it will also reduce interior heat especially inthe tunnel area between the seats.
Old Jul 17, 2003 | 12:33 PM
Salty's Avatar
Salty
Thanks to everyone for the help!
Old Jul 17, 2003 | 06:47 PM
RunNE1's Avatar
RunNE1
Default Re: Sound Deadner (KingTut)
You should also look into some of the other barrier materials from Cascade Audio. The spray on stuff does not work as well as the barrier mat type insulators. As I understand it a three layer mat works best. You have and open cell layer acting as a decoupler b/w 2 closed cell layers.
Old Jul 17, 2003 | 08:47 PM
Mike Mercury
Default Re: Sound Deadner (RunNE1)
:confused:
someone here showed a pic of a material (I think it was made by Cascade) that was identical to the FK product... even the same thickness. They're probabably made by the same manufacturer.
from a post on the LS1 forum:
... I went to Lowes looked over my shoulder and cut off a little piece. It is exactly the same as cascade mat.
I guess this makes it "real" ???
Also there is about 15 stories on this forum (and on LS1 forum) from those that used it and were very pleased with the FrostKing. It is low density so not suited for high wattage stereo applications. But for the average Joe that wants to inexpensively quiet down a stock Vette; it works well... unless everyone lied about the results?
If money and weight increases were no worry... the more dense offerings will provide better dampening.
The Reflectix is light weight as well.
read about others experience:
I just did this to my car and cut the noise in half, LITERALLY! Go to HomeDepot or Lowes and pick up 5 (I only used 4) of these:Frost King
click here: post #1 of many
and here is another user of the Frost King:
I installed the Frost King duct insulation in my car today. I ended up using 5 rolls. Took me about an hour to get the entire interior out, 2... The insulation sticks and conforms easily to the metal. The interior NOISE is significantly reduced.
full text here: post #2 of many
if you understand how "dampening" works; any product that is dense and adhesive backed will lower the resonate frequency of a surface and inhibit it's ability to vibrate (keeping it from passing the sound from one side to the other).
[Modified by Mike Mercury, 7:54 PM 7/17/2003]
Old Jul 18, 2003 | 09:51 AM
Salty's Avatar
Salty
Default Re: Sound Deadner (Mike Mercury)
Mike, Thanks for the excellent detailed response. This weekend I will try the frost King and will report by next week the results. :hurray:
Old Jul 18, 2003 | 10:13 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Default Re: Sound Deadner (TimC5)
:iagree: Did this and it WORKED. My Vert is LOUD, very LOUD (see sig). I am a firm believer.
:cheers:
Old Jul 18, 2003 | 11:14 AM
SNISTER's Avatar
SNISTER
A good way to reduce the NVH inside your car is to replace those awful runflat tires with something else.
I was considering sound deadening material until I put some new tires on. I can now listen to my radio and talk to the person next to me without shouting.
To Sound Deadner
