Hurst shifter, should I install one???
Old Jul 19, 2003 | 01:15 AM
topless99's Avatar
topless99
Default Re: Hurst shifter, should I install one??? (SLICKMAN)
where did you get the shifter for that price?
Old Jul 19, 2003 | 02:10 AM
MagRed2002's Avatar
MagRed2002
Default Re: Hurst shifter, should I install one??? (topless99)
I've heard alot of talk about the "Hurst Vibration". I am sure the cases related here on that topic are all genuine, but perhaps rare.
Case in point: Being indecisive as well as **** retentive, I have tried at least a half a dozen different shift ***** on my Hurst since I got it over a year ago. Regardless of **** - MGW, Extreme, Kirban Billet, Stock, Momo, etc - Ii never experienced vibration. As someone related earlier in this thread, it may be specific vehicle dependent rather that shifter brand dependent.
I love mine. Go with the Hurst!
Old Jul 19, 2003 | 08:20 AM
SLICKMAN's Avatar
SLICKMAN
I found it brand new off EBay
:D
Old Jul 19, 2003 | 02:37 PM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
One word, get the "Ripper" :steering:
Old Jul 19, 2003 | 07:32 PM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Default Re: Hurst shifter, should I install one??? (VETTENV)
:skep: ...that's five words. :confused:
:D :rofl: :rofl:
Old Jul 19, 2003 | 07:53 PM
w8d4it's Avatar
w8d4it
St. Jude Donor '04-'05-'06-'07-'08-'09
Default Re: Hurst shifter, should I install one??? (NVR BRNG)
I would love to know what you did to avoid vibration. I have tried everything, various adjustments, weights, tape, sound deadening material, MGW ****...you name it. Still everytime I get it on the thing rattles like crazy. Never did with the stock shifter. I really like the Hurst and have no plans to swap it out but I'd be a lot happier without the vibration.
So if you have some tricks for quiet please help us all and post them. If you can't post then please email me. I'd be greatful.
NVR BRNG
Senior Member
65 posts [100%]
Walnut CA
Re: Hurst shifter, should I install one??? (SLICKMAN) 11:58 PM 7/16/2003
YES!
EZ Install, & Vast Shifting Improvement and DRIVING PLEASURE!
E-mail me for some install tips, no tape, weights, etc. needed. I've installed 18 Hurst for friends in So. CA. I don't claim to be an "expert", but I can give you some tips if you are going to DIY.
Very good mod, you'll feel more Connected to your car and will ENJOY the mod.
[Modified by w8d4it, 6:55 PM 7/19/2003]
Old Jul 19, 2003 | 08:50 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: Hurst shifter, should I install one??? (w8d4it)
The problem is that the ****'s threads are to lose on the shaft. Put some electrical tape on clockwise and let it extend beyond the top of the shaft. This is so that when you screw the **** on it will bottom out on the tape that you left protruding above the shaft. This should stop the rattle. If the electrical tape is to thick try plumbers teflon tape. Good luck a let us know the results.
Old Jul 19, 2003 | 09:00 PM
boost2much's Avatar
boost2much
Default Re: Hurst shifter, should I install one??? (edpainter)
Its one of the best mods I've done to date. I wrapped mine with a bit of electrical tape to help the momo shift **** stay tight. Haven't had any problems with rattling or anything else.
:cheers:
Old Jul 19, 2003 | 09:02 PM
SLICKMAN's Avatar
SLICKMAN
This is good to know and it makes perfect sense.. :yesnod: :thumbs:
[Modified by SLICKMAN, 9:03 PM 7/19/2003]
Old Jul 19, 2003 | 09:30 PM
Tom Steele's Avatar
Tom Steele
Sorry, but that is not the problem with mine. I did EVERYTHING but put the stock shifter back on.
Old Jul 20, 2003 | 05:31 AM
Stock Man's Avatar
Stock Man
Default Re: Hurst shifter, should I install one??? (Tom Steele)
So it's not the **** that's rattling? Maybe you've lost the springs or stops that screw into the housing? What exactly is rattling?
Old Jul 20, 2003 | 06:19 AM
w8d4it's Avatar
w8d4it
Tom's problem is just like mine. Perfectly quiet stock, Instal hurst, get on it and the rattel will rive you nuts' I've done the adjustmrnt tape routine routine. Also screw adjustment unhelpful
Any suggestiohs. I am a bout to go back in again remove the sounde deadener and screewsk springs aall togrert
Old Jul 20, 2003 | 07:47 PM
  #33
Tom Steele's Avatar
Tom Steele
I believe the transmission has a rattle that is being transmitted up the Hurst shifter. The stock shifter has an isolater on the lever, which helps r3duce the chance of the transmission sending a rattle up the handle.
I have done it all. I have an overprices solid aluminum ball on the top of the shifter now, in order to eliminate the possibility that the OEM shifter handle was loose and allowing the plastic insert to rattle. I have taped the threads like crazy with teflon tape, to the point I couldn't thread the ball, and had to back off a little!
I have put an AMAZING amount of sound deadener under the shift boot (it poofs UP now) in order to try and quiet it down.
It is barely tolerable. I debate going back to stock anytime anyone rides in the car with me, then change my mind the next time I have to make quick 2-3 shifts...
