Unknown Codes
Old Jul 16, 2003 | 11:02 PM
alamo1974's Avatar
alamo1974
Default Unknown Codes
Can someone help me tonight. I had my check engine light come one tonight and did a test on the codes and the following came up:
BO-RFA U1096H
BO-RFA U1064H
BO-RFA U1016H
What do these codes mean???????????
After doing the diagnostic test the check engine light went off.
Can you help.
Thanks :confused: :confused: :confused:
Old Jul 17, 2003 | 07:15 AM
THRAP 42's Avatar
THRAP 42
Default Re: Unknown Codes (alamo1974)
Alamo1974,
Those 3 codes together require you to contact the dealer, there is a information they have on those codes being in history that I don't have access to.
Here's a link that list the codes http://forums.corvetteforum.com/zerothread?id=600794
or you can visit my homepage, they're listed there too.
later,
[Modified by THRAP 42, 6:22 AM 7/17/2003]
Old Jul 17, 2003 | 11:47 AM
mapman's Avatar
mapman
BO-RFA U1096H
BO-RFA U1064H
BO-RFA U1016H
Can you help.
The codes indicate a communication problem among the modules.
U1096 - Instrument Panel Cluster (IPC)
U1064 - Body Control Module (BCM)
U1016 - Powertrain Control Module (PCM
The "H" indicates it is a "History" code and not current. After running the car do the codes come back?
Old Jul 17, 2003 | 07:57 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Dont worry about those particular codes. They are very common among all C5's. They often occur when the systems are communcation between each other, and a signal takes priority on the system bus, and knocks another off, making it resend. No big deal.
To Unknown Codes
